Originally Posted by
Hugo Holden
There are some general principles that apply to all VDU CRT's.
The maximum useable beam current and display brightness occurs when the cathode and grid voltages are equal. If the grid is driven, by the video signal content (call it the peak white, or peak amplitude of the video signal) more positive than the cathode, it causes the grid to draw current, then the form of the beam changes and the focus suddenly degrades. In addition if the CRT bias is pushed this way, then the H and V blanking pulses (positive going if introduced at the cathode and negative going if introduced at the Grid) may not have enough amplitude to blank the beam, so retrace lines will appear.
Most color CRT's have a screen and screen control, it's less common on monochrome VDU's.
The contrast control alters the amplitude of the video drive to the CRT and the brightness control the DC axis of that signal.
So when both are set correctly and for the max useable brightness of the phosphor on the CRT face, the peak white of the video signal is just approaching the zero grid to cathode voltage condition, and the black part of the video corresponds to the CRT beam just extinguished, and the sync pulse tips (present in composite video at least) drive the beam "blacker than Black" so to speak.
It is fairly easy to tell if a CRT is down on emission. If the combination of brightness (and sub brightness) and contrast ( and sub contrast controls) are set for max phosphor brightness, just before the beam significantly defocusses, indicating that the zero grid to cathode voltage condition exists, then if it is a dim image, the CRT is likely low on emission or has a very degraded phosphor, or is gassy or all of the above. This assumes the EHT value is normal,heater temperature normal and if there is a screen pot, that has been correctly set.
If there is any doubt, a scope can be used to check if the CRT's cathode is being driven more negative than the grid (or the grid being driven more positive than the cathode) which ideally should never happen to avoid grid current and severe defocus.
On the topic of re-phosphor of a CRT, it is extremely difficult. The phosphor is placed in a liquid suspension, and allowed to settle out , the liquid is decanted and it is dried, a binding agent , a silicate is used to help it adhere,then aluminium is evaporated on it. I tried it once with a 12LP4 CRT and failed hopelessly, it requires automated machinery. The ETF are building a CRT plant. But re-gunning and re-phosphoring CRT's is difficult. It worked in large scale industry because of the automation and controls, much like manufacturing semiconductors, very hard in a backyard operation.
