Hey all,
So I recently got a Intel Professional Workstation 486, and I've been doing my best to try and get it going again. I actually did a video demoing this system (https://youtu.be/fK7QMAX0BmQ), and am hoping someone here might be able to help. It's an EISA based/SCSI monster with some pretty non-standard stuff.
Right now, the system is suffering dead Dallas-itis, so I'm waiting for a replacement to arrive from DigiKey; I'll only dremel the DS1287 if I absolutely have to. That part isn't a major problem.
The problem is the PSU in this system is a pile of dog doodoo. The video shows it pretty clearly, but I feel like this entire thing is just waiting to go *poof*, and more problematically, the PC speaker lives *in* the PSU. To be honest, I'm sorely tempted to bin the thing and see if I can rig an adapter to a micro-ATX or similar. The PSU label says it provides 12+/12-/5+/5- so I'll likely need an adapter board to get the -12V rail out of anything modern. The mainboard has a 20 pin pin connector that the PSU sorta slots into, so I'm guessing I need to rig some sorta breakout board. If I remember my electrical theory 101, I need to be in series to measure voltages which should make this a semi-interesting challenge. (I'm not an expert here).
Alternatively, I could try and rehabilitate this PSU and re-cap it; the caps seem good, and it's def. working, but there I'm stemmed by a stripped screw in a very inaccessible locations. I've got a small set of pliers on the way that might be able to reach the stem and turn it, but I'm not super optimistic.
Any advice would be welcome; also, is there anything specific I need to know about EISA systems specifically? I did find the EISA configuration utility and reference files for this system, but I'd prefer to know any potential landmines *before* I hit them. I've posted some stills here (https://imgur.com/a/jZJci2W), and can post more if they will help.
