Results 1 to 10 of 17
Thread: Is there a way to detect a Plantronics Colorplus card by software?
    Default Is there a way to detect a Plantronics Colorplus card by software?
    I read the invaluable information at seasip.info. I read on this site that the Plantronics Colorplus has a register to activate the additional plane needed to use its 16 color special mode(port 03DDh). The problem is that this register is write only. I also tried to write and read a value at the second plane adress (0BC000h), but it returns the same value also in regular CGAs.
    So, Is there any way to detect a Plantronics Colorplus card by software, distinguishing it from regular CGAs?
    Thank you very much for your help.
    I mean, it's not very scientific but you could run Planet X3 and select plantronics colorplus as the video mode and see if it works? the game loads super fast on even a 4.77mhz 8088 from a 360k disk.
    Quote Originally Posted by carlos12 View Post
    Maybe by using logic. If there is 32 kb video RAM and it's not Tandy, it can't be much else than Plantronics.
    Outer Mongolia
    3,229
    A normal CGA card is not fully decoded, IE, the contents of the 16k from B8000-BBFFF also appear from BC000-BFFFF. Therefore if you write a value to BC000 it will indeed read back, but the same value should *also* read back from B8000. I assume a Plantronics in CGA-compatible mode behaves the same way, but what if you set the register to enable its special mode? Presumably those two locations would become "unlinked", IE, a write to B8000 would no longer affect BC000 and vice-versa.
    Thank you everyone for your ideas.
    Eudimorphodon: yes! You are just right! I finally managed to distinguish a Plantronics from a regular CGA. I wrote this assembly code:
    	mov  ax,0BC00h
        	mov  es,ax
        	mov  di,0
    	mov  al,121
    	stosb                  ; Writting a random value to Plantronics second plane at 0BC00h
    	mov  ax,0B800h
    	mov  es,ax
    	mov  di,0
      	mov  al,121
    	cmp  es:[di],al
    	jne   isPlantronics ; If there's a Plantronics, the value inserted at 0BC00h does not wrap into 0B800h
            ; Do whatever you want to do with a regular CGA here
    isPlantronics:
            ; Plantronics code
    This code must be used after assuring the card is a CGA. Other cards such as EGAs and VGAs wrap the video memory adrresses, so they could give a false positive. We must also set a regular CGA graphic mode, and writting to 03DDh port must, just as explained at seasip.info. For 320x200x16 colors I sent 16 as a value (00010000).
    One thing that confused me a lot was DosBox: at least on 0.74 version, it gives a false positive as it wraps the addresses even when set on CGA mode.
    Thank you for your help!
    I think you can eliminate the false positives by trying to swap the address mapping of the red/green and blue/intensity pages. If that works, you can be pretty sure it is a Plantronics ColorPlus.
    What could turn out to be problematic, though, is that other enhanced CGA chipsets or CGA+HGC combo chipsets use the same 3ddh register for something else.
    This means that you cannot really use your code as a generic unsupervised detection routine. That is: You could, provided that your code tries to detect or rule out everything and anything in the correct order.
    You could indeed use Planet X3 as a visual test, but it does not check anything before it tries to switch to Plantronics mode. It will blindly trust the user input and do funny things when the expected hardware is not there.
    Hi, Benedikt. Thank you for your input.
    I tried the procedure described above on several video cards, all of them via emulation on 86Box, and it seems to work fine. The problem, as you say, is that there are too many different cards. 86Box emulates a lot of them but for sure there are even more. But for most cases, at least with the most frequently used cards, it seems to be ok.
    Detailing a bit more the process:
    - First, I make sure that the program is running on a CGA, discarding EGAs, MCGAs, VGAs, HGCs et al. I use a much longer detection code, expanding the one used on the VGA Xmode Xlib, but this is a snipet of the CGA part (the program previously detects more advanced cards, so this code never gets executed on, for example, a VGA):
    	mov  al,4
    	mov  ah,0
    	int  10h				 ; Set CGA med resolution 4 colors mode
    	xor  al,al				 ; al = 0
    	mov  ah,0fh		         ; Test if mode changed
    	int  10h
            cmp  al,4
            je  isCGA
    - Then I activate the ColorPlus special mode
           mov dx,03DDh
           out  dx,00010000b
    - I finally apply the code that I posted above
    I also add a test to see if the program is running under DosBox. This part is written in C:
       bool DosBox()
           struct stat buffer;
           if (stat ("Z:\\COMMAND.COM", &buffer) < 0)
               return false;
           else
               return true;
    If runs under DosBox, for sure it's not a Plantronics.
    Anyway, in my program I give the user the option to choose whatever the mode s/he wants to use. The detection is only indicative. But the case of the Plantronics is a bit special, as my program only offers the 16 color mode if detected, in order to not confuse the user.
    BTW, I just love the work you did with the additional modes for Planet X3. I'm really impressed with the 320x200x256 colors to 640x200x16 colors dithering. Would love to know more about it. Congrats!
    6,987
    FYI, the Olivetti M24 (and variants), and some compaqs, have 32K of display RAM as well. So just a simple test for 32K won't tell you if it's plantronics or not.
    You probably don't need to worry about this because you don't support the M24 400-line mode. But if it becomes necessary to differentiate between plantronics, M24, TandySL/TL, etc. then this might help:
        {Key kids, let's do all sorts of extended CGA adapter detection!
        Tandy, PCjr, AT&T 6300, Compaq Portable III, you name it!}
        {First, the PCjr/Tandy family, as they have relocatable video ram.}
        {PCjr, Tandy, Tandy SL/TL code inspired by Jason Knight}
        asm
    	    mov  ax,$FFFF
    	    mov  es,ax
    	    mov  di,$000E     { second to last byte PCjr/Tandy BIOS info area }
    	    cmp  byte ptr es:[di],$FD  { ends up $FD only on the Jr. }
    	    jne  @notJr
    	    mov  result,1 {videoCard_pcJr}
    	    jmp  @done
        @notJr:             { not junior, test for tandy }
    	    cmp  byte ptr es:[di],$FF  { all tandys have $FF here }
    	    jne  @notTandy
    	    mov  ax,$FC00
    	    mov  es,ax
    	    xor  di,di
    	    mov  al,$21
    	    cmp  byte ptr es:[di],$21
    	    jne  @notTandy
    	    mov  ah,$C0
    	    int  $15          { Get System Environment }
    	    jnc  @tandySLTL   { early Tandys error out, TL/SL does not }
    	    mov  result,2 {tandy1000}
    	    jmp @done
        @tandySLTL:
    	    mov  result,3 {tandySLTL}
    	    jmp @done
        @notTandy:
    	    mov  result,0 {all other cards eliminated, must be CGA}
        @done:
        end;
        case result of
          1:s:='IBM PCjr';
          2:s:='Tandy 1000';
          3:s:='Tandy 1000 SL/TL';
        end;
        {Now check for specific adapters based on various criteria.
        This was really tough for me; I tried all sorts of ideas to detect
        these adapters and modes, but in the end, such bit-banging is not
        safe.  A true "universal" 640x400 detector is just not possible without
        the possibility of crashing unknown hardware.}
        asm
          {First, check for AT&T/Olivetti using the model byte, which they
          have been so kind as to implement broken (returns 0000)}
          mov     ah,$C0
          int     15h          {6300 has NO 15h support in BIOS }
          jc      @ATTFound    {if CF=1, error; try to detect 6300 some other way}
          mov     ax,es:[bx+2] {grab model word}
          cmp     ax,$01FC     {See if we're on the Compaq 400-line adapter/plasma}
          je      @CompaqFound
          jmp     @error
        @CompaqFound:
          {We think we are on a Compaq Portable III.  Let's see if we can detect
          the internal plasma monitor.}
          mov     dx,1BC6h
          in      al,dx
          mov     cl,4
          shr     al,cl
          mov     result,al       {If this is plasma, result=4 if 400-line}
          jmp     @done
        @ATTFound:
          {Let's try a second check for the 6300/M24.
          Run a 6300/M24-specific BIOS INT.  If it returns info, we are SURE
          we are on a 6300/M24 and try to grab monitor ID bits from 3dah.
          ;Int 1A/AH=FEh
          ;AT&T 6300 - READ TIME AND DATE
          ;AH = FEh
          ;Return:
          ;BX = day count (0 = Jan 1, 1984)
          ;CH = hour
          ;CL = minute
          ;DH = second
          ;DL = hundredths}
          xor     cx,cx
          mov     dx,cx
          mov     ax,0fe00h
          int     1ah
          or      cx,dx            {if any bits are set anywhere, we have 6300/M24}
          jcxz    @error           {no bits?  No 6300/M24!}
          mov     dx,03dah         {a monitor ID in bits 4-5 (2=colour, 3=mono}
          in      al,dx            {If a DEB is present, bits 6 and 7 will be 0}
          mov     cl,4
          shr     al,cl            {discard regular status bits}
          test    al,00000010b     {if 2 or 3, bit 1 will be set and we have AT&T}
          jz      @error
          mov     result,al
          and     result,00000011b {mask off DEB bits}
          test    al,00001100b     {if these are unset, we have a DEB}
          jnz     @done
          or      result,10000000b {set bit 7 if DEB present}
          jmp     @done
        @error:
          mov     result,0         {must have made a mistake...?}
        @done:
        end;
        {check our results and set the string}
        case (result and $7F) of
          2:s:='AT&T/Olivetti (Color Monitor)';
          3:s:='AT&T/Olivetti (Monochrome Monitor)';
          4:s:='Compaq Portable III (Internal Plasma)';
        end;
        if (result AND $80)=$80 then s:=s+' + DEB';
    Outer Mongolia
    3,229
    When the M24 isn't set up for an extended video mode does it replicate the 16k wrapping behavior of plain CGA, or is the extra 16k always there?
    6,987
    By sheer coincidence, I happen to have my 6300 right next to me. Let me check...
    A quick test with debug shows that the extra 16K memory is indeed active whether you're using a 32K mode or not.
