Ok, I have my system somewhat back together. I'm currently on the Universal board with 81-478a ROM. I am using the MSDOS.COM and RAMDISK.COM from http://www.retroarchive.org/maslin/d...o/copwrcpm.td0
and booting MSDOS disk http://www.retroarchive.org/maslin/d...o/copwrdos.td0.
The system can also boot the MS-DOS 2.11 disk at http://www.zorba.z80.de/files/swp/dos211-1.td0 However, with this disk, I get some errors in the protocol running between MSDOS.COM and the firmware on the COPOWER 88. You can demonstrate this type of failure by running basica.com of the disk from zorba.
If I remember correctly, the DOS 3.3 disk from Zorba also works: http://www.zorba.z80.de/files/swp/dos330.td0, but, not the CPM86 disk that is there.
I am using CPM 2.2u1 when running the utilities, and not the CPM that are on the disks.
The port number used in these programs is 07Eh. This was the result of my disassembly. I'm including pictures of my board, where you can see where I cut a trace to get my board to respond. Please see the 2nd picture.
Here is a picture of my system booting the Zorba Dos 2.11 disk. However, the Maslin disk works better.
So far, the MSDOS.COM off of the K10 disk you sent only seems to hang. But, upon hex comparison, it has a lot more data than the file that I retrieved off the Maslin archive. I'm still looking into how to get this file working / running. More to come.
Unfortunately, I accidentally used a CPM 2.2F PUTSYS.COM command which trashed the hard disk under CPM 2.2u1 and I have to rebuild the hard disk again.....So,
That is what I have for now. I'm going to work on getting the K10 MSDOS.COM to work. I might switch over to the 81-302 board to see if it has something to do with the BIOS / Board.
Let me know if you have any questions.
Chris V.
