Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: S-100 Power Supply Design Question
    Feb 2015
    Cleveland, OH, USA
    1,360
    Default S-100 Power Supply Design Question
    Pardon me for asking; I know little about the specifics of the S-100 standard but out of curiosity I have begun building a system using Monahan-design boards. I have the backplane finished except for an op-amp (which the USPS is sheltering in an undisclosed location) and have acquired a nice big case to house everything. Soon it will be time to provide power and that brings me to my question:
    On the advice of the Google S100 group I will try to use switching power supplies instead of a linear supply, as was the custom back in the day. One Meanwell 7.5VDC 10A will provide 8 Volts (they assure me it can be "tweaked" up to 8V) and two Meanwell 15.5VDCs to provide plus and minus 16VDC. If I understand correctly they are yoked - + : - + to provide the 32V differential. (It's always possible I don't understand correctly, however.)
    Is this a good idea? Are there any caveats about this plan? Is there a better solution?
    Thanks for your suggestions.
    -CH-
    Yes, your plan should work. I have this arrangement for my open frame S-100 system. In the (low res pictures) the switching power supply on the top is (+16V), the middle one is (-16V) and the bottom one is (+8V). For the +/- 16V supplies the green GND wire is on the -V for the top supply and on the +V for the middle supply. This seems to work fine for me.
    >>> Charles
    4,891
    If you don't need a ton of +/-16V (and most systems don't) you can use a single Mean-Well RD-3513 and turn the voltage up to +/-15V (it's nominally a +/-13.5V supply). That's what I typically use, saves a little space and cost.
    36,416
    You should be fine--note that the S100 spec of +8V is only approximate and is done to provide sufficient line supply headroom for the pretty-much-universal linear on-board 5V regulators. That +8 is assumed to be nominal and unregulated.
    If the line (as in line-versus-load) supply is too high, the on-board regulators will get very hot, as they just dissipate the excess voltage as heat as pure IČR losses. If the line voltage is too low, you sacrifice regulation and have to confront the possibility that the load side will sag below 5V.
    For nostalgia's sake, I like the old linear "boat anchor" supplies. You may want to consider building your own, as for S100, they're rarely more than a big transformer, rectifier and capacitor setup. Integrand used to advertise with their S100 boxes that they wound their own transformers.
    Old 6.3V filament transformers should still be pretty plentiful. With a Schottky bridge rectifier and generous capacitors, the voltage should be right around 8V.
    If you're interested in building a boat anchor linear S100 supply, it can be done with a single 12.6V CT transformer which is pretty standard. Back in the 70's, I built one from the following circuit and it was still working up to a year or so ago when I finally sold the system.
    Note that this is for older S100 systems and 15+ Amps at +8V plus 3A at +/-16V. If you're using just a few of the newer cards with linear regulators on them, the component sizes (and costs) could be reduced.
    36,416
    You could also go the "really DIY" route and take an old microwave oven transformer and rewind the secondary. Beefy.
    YT video
    Reminds me of my old ham days when you'd rewind old TV power transformers (and they could get pretty darned big back then).
    Sep 2006
    Silicon Valley
    2,464
    Quote Originally Posted by clh333 View Post
    Leave it at 7.5
    The voltage difference is being dissipated as heat in the linear regulators so they will just run cooler.
    https://electronics.stackexchange.co...ow-minimum-vin
    so 5 +1.8 = 6.8 minimum
    Quote Originally Posted by Dawsoca View Post
    >>> Charles
    I use the same setup, and the supplies are slightly tweaked to get closer to the expected voltages.
    @Dawsoca -- I really like the cage you built for your setup. Is there a CAD drawing of it anywhere? I'm not using the same motherboard (which looks like the S100 Computers 8-slot), but I do have one of those handy. How about the card guides? 3D printed? It's a very awesome look. Mine is just plywood (kind of hacked together) so I wouldn't mind re-doing it.
    Rich
    Leave it at 7.5
    Yes, I agree with this. With the original analog supply (transformer, rectifier,filter capacitor) the S-100 on board regulators (like 7805) the input voltage needs to be a little higher than 7.5V (average) because of the supply ripple and not wanting the troughs to drop below 7.5V. But with a ripple free output from the SMPS, you can run it right on 7.5V which satisfies regulators like the 7805 and it keeps the heat dissipation in those regulators as low as possible.Generally for the vintage 7805, the minimum input voltage is 7.5V, but I have found many keep regulating a little below this value.
    Hello Rich, yes I have a print for the open frame S-100 project (enclosed). It is based on the
    older version of the S-100.com 8-slot motherboard. It should work for the 9-slot one with
    adjustments. The card guides were purchased from Mouser (Bivar VG2-5). You don't need the
    power-on delay relay setup but I like it as it prevents me from removing cards with power on and
    it allows the supply to stabalize during turn-on (mainly for linear supplies-not so much for the
    switchers).
    >>> Charles
    S100_Draw.zip
    Relay_Delay_On.zip
