All the DEC made boards in the LAB-8/E I am restoring have their IC pins bent presumably to keep them in place during assembly.
The soldering looks terrible so I don't think these were wave soldered but rather soldered by hand. The LAB-8/E was made in Puerto Rico so labour cost was cheaper than fancy equipment.
Until now I had to only remove a single 14 pin TTL IC (74H40), but it defeated my de-soldering station because of the bent pins.
Normally I can desolder each pin and the IC just falls out, but not on these DEC boards.
I ended up cutting every pin at the point where it exits the IC body and then using a tweezer and soldering iron removed each pin individualy. Even this was painful because of the sharp bend of the pins and the quick dissipation of heat once you touched the pin with the tweezer. It took a lot of effort (and a few four letter words) to succeed.
What is the best approach for the removal of ICs with bent pins on these DEC boards?
Thanks and best regards
Tom Hunter
