January 17th, 2021, 08:08 AM
#1
ISC Intercolor 8001
Does anyone have a running Intercolor?
I am just about to drag one out of storage to see if it works, so any help will be appreciated 🙄
January 17th, 2021, 04:26 PM
#2
SteveG,
Check out this thread for a working color Intercolor terminal:
http://www.vcfed.org/forum/showthrea...197#post643197
That thread was about Tektronix 4027 compatibility.
I've recently been working on my Tektronix 4041 GPIB Controller, and with a Tektronix program called EZ-TEST, which requires 4105 or 4107 color terminal compatibility.
January 18th, 2021, 03:14 AM
#3
Hello Monty,
My Intercolor is larger and I suspect older than the photo on this thread.
I remember having my trip to the Budapest Academy of Science being delayed for 6 months by the US military because the Tektronix display was barred at the time from being shipped to Iron Curtain countries. It was OK to ship the PDP 11 part of the Mass Spectrometry Data Acquisition System but not it’s Tektronix display. NB. I did not meet him but Professor Rubik the inventor of the Rubik’s Cube had an office in the corridor where the Mass Spectrometry department was located.
January 18th, 2021, 06:47 PM
#4
Here is a video of my intecolor 2427 running https://youtu.be/SvO5k9Cwt88
Do you have any manuals for your terminal? Pictures? Mine only took a good cleaning and some wire wiggling to get mostly working.
January 20th, 2021, 02:34 AM
#5
My ISC is an 8052.
Here are some pictures:-
NB. I don’t think I have any documentation but I have not had time to check.
January 20th, 2021, 05:18 AM
#6
Wow! The presence of the floppy drives appears to indicate you have the 8080 computer version of the Intecolor!
January 20th, 2021, 06:31 AM
#7
Is that
1) good
2) bad
3) unusual
January 20th, 2021, 08:57 AM
#8
I would say that is good as it sounds like you have a Compucolor computer from the 1970's or early 1980's:
https://en.wikipedia.org/wiki/Compucolor
a little more searching found that due to the micro floppy drives in your photo, it may be an Intecolor 3600 prototype using the original ISC monitor and a prototype computer with the 3.5" drives.
The first Intecolor computers with Micro drives appeared to be the 3600 series:
http://www.dvq.com/ads/isc_3600.pdf
Lots of docs on this site:
http://www.compucolor.org/docs.html
January 20th, 2021, 10:44 AM
#9
The keyboard has no base as I assume it was mounted in a control panel.
January 20th, 2021, 03:09 PM
#10
I have a manual for a Colortrend 427; not the same I suppose, despite the '427'?
- You may not post replies
- You may not edit your posts
Forum Rules
