Acquired the model 26-3022 from an eBay seller and quickly found why it was "parts only": A mouse had established residence at one point and in addition to importing paper and foam bits and using the floor for a lavatory had chewed signal wires and their insulation. A few other problems are visible; some of the electrolytics appear to have leaked, for example, but the real problem is I have no documentation for this drive.
I can find docs for the earlier 16-xxxx drives that were used with the Model I but there are jumpers and wires and test points on this thing that I don't recognize, as well as a drive with a different latch, a different drive belt (looks like yellow cellophane) and a few other features that are recognizable from a functional point of view but different in placement and / or form.
As always, any insight appreciated.
-CH-
