Results 1 to 4 of 4
Thread: IBM 5155 and sound card 8 bit ISA
    Default IBM 5155 and sound card 8 bit ISA
    Hi,
    Which sound card can I use on an IBM 5155 8 bit ISA, do you have any references?
    Thanks for your help.
    Any old sound blaster should work, the 5155 shares the 5160 system board.
    7,060
    The quick answer:
    Sound Blaster
    Sound Blaster 1.5
    Sound Blaster 2.0
    Sound Blaster Pro
    Sound Blaster Pro 2
    Adlib
    ...or any card with an 8-bit ISA edge connector that claims to be compatible with the above.
    The complicated answer is that there are many more boards you can use, like a Pro Audio Spectrum 16, or even an early Sound Blaster 16, but the above list is good enough for beginners.
    thank you for your response.
