Hi,
I've got this Siemens PCD-5T Pentium 60Mhz that I decided to try and get up and running.
The computer has an Adaptec 2940 PCI SCSI card with a Conner 540MB HD.
When I first started the PC I got the following messages :
So realtime clock failure and fixed disk configuration error (?).
The Adaptec seems to load the bios and the disk is also installed on startup.
I replaced the Dallas chip but after that the following happened :
Realtime clock failure and fixed disk configuration error disappeared.
But this time te Adaptec bios was no longer installed (but I could go into the SCSISelect utility and see the drives)
Also :
- When I placed the original Dallas chip back in, the Adaptec again was able to load the bios on boot.
- When I placed the new Dallas chip back in, the Adaptec failed to load the BIOS.
I have no idea how to enter the CMOS setup of this computer (Don't even know if there is one, or if there is some kind of setup disk).
There is very little info on the computer.
I found a setup program here : http://oldcomputers-ddns.org/public/...-5t/index.html
I found the motherboard layout here : https://arvutimuuseum.ee/th99/m/S-T/33370.htm
But the only setup program I have is the Siemens EISA setup utility, and I cannot change the system configuration because it is password protected
I didn't find any operation manual or other system disk.
Any ideas how I can proceed with this ?
