Originally Posted by
Old_hitech
Thanks for the replies. Appreciate the detailed explanation on 24-bit MacDraw. I am experiencing FloppyEMU HD20 mode crashes and errors when I just boot to System 7.1 and check the About menu and open and close a couple of folders then select Shutdown and turn on my SE/30. When I turn it on again and it tries to boot to System 7.1, but gives error like Finder is missing or -127 error. I have not even tried to run an application. I have just tried some basic system/finder tasks. Very strange.
I'm an about to order a SCSI2SD from inertial computing and have some questions. I like the internal drive model and there seems to be different version numbers of V5.1 or V5.2. Which one should I get? Also does the mounting bracket fit and mounting screws holes align okay with the SE/30?. I am also going to need a floppy to 4pin Molex power harness. I have a MacBook Pro running macOS Mojave. What is the easiest way to build a hard drive image of System 7.1 for the SCSI2SD?
