Originally Posted by
shirsch
I found it easier to tweak settings from the PC while watching the unobstructed display. But, more importantly, you cannot save a truly complete preset without issuing serial commands. It's sort of glossed over in the manual, but the three 'user' presets accessible from the on-screen dialog do not capture the specific input settings - only the mapping between input scan frequency and output. With the Corvus this was particularly annoying and I had to reenter 90% of the information on the input settings page every time. There is a second set of memory locations that captures 100% of the parameters and recalls them automatically. They call these 'input' presets and they are only available by talking over RS232. You could issue them from a terminal program using the documented syntax in the manual, but it's a one-click operation if you are talking to it from the control software already. This is discussed on p 19 of the manual.
