Results 1 to 10 of 23
Thread: How do I interface a TRS-80 Model I to a TV or Composit video monitor?
    Apr 2007
    Saraland, AL just north of Mobile
    72
    Default How do I interface a TRS-80 Model I to a TV or Composit video monitor?
    I recently acquired a TRS-80 Model I Level II 16k with a power supply; but I don't yet have a Tandy Video Monitor. In searching the Web, I have run across a few references on interfacing a Model I video output to a TV or Composit Monitor but there are no details on how to do it. The Din-5 provides sync, video, +5 and ground. What is the schematic to feed these into a composit RCA jack on a TV or monitor?? Any help would be appreciated.
    Connect ground (pin 5) to the shield of a piece of coax (terminated in an RCA connector), and the video signal (pin 4) to the tip. You will then have a standard compsite video out.
    Do NOT CONNECT ANY OTHER PINS. There is 5V lurking there that can cause smoke to come out.
    Hamilton, Ontario, Canada
    3,788
    Yeah, I used to make the cables all the time by just taking and old AT keyboard cable and soldering an RCA jack to the wires that corresponded with pin 4 (data) and pin 5 (ground). Plugged right into the video output jack.
    BTW, an ordinary AT style keyboard extension cable is great for using as a monitor cable extension on the model 1.
    Legacy Computers and Parts
    Jul 2003
    Västerås, Sweden
    6,277
    On the topic, but slightly different question. As you know, I received the TRS-80 Model III with a smashed monitor this summer, and I haven't had the time or motivation to try find another tube. However there is a cable from the motherboard to the monitor circuit board. I have downloaded some service manuals, but didn't look into them. Does anyone know if the Model III on this connector also has a "standard" video output that I could tap and feed into another monitor? If yes, I may be able to locate the pinout, but as long as I don't know if I should expect to find what I'm looking for, I may look in vain.
    Anders Carlsson
    Quote Originally Posted by carlsson View Post
    I have no answer for your question, but I feel your pain. I too got a Model III that wasn't packaged correctly and the monitor imploded. My solution was to track down a Model IV and use the III for parts.
    Bill Loguidice, Author
    Managing Director, Armchair Arcade
    About Me
    Jul 2003
    Västerås, Sweden
    6,277
    Even if I can get video from the computer, it probably will be NTSC at best. Maybe I'll find time in November to look into this. First I need to follow Druid's advice how to adopt the unit to 220-ish voltage.
    Anders Carlsson
    Quote Originally Posted by Druid6900 View Post
    My apologies for resurrecting an old thread, but I just have to say thanks for this. My old Model 1 video cable disintergrated at the DIN end last week. I googled to get some repair advice and came across this post.
    A few days ago, I sourced an old AT keyboard at work gathering dust under a lab bench and snipped off the cable. Before retiring tonight (and after cleaning up after Xmas festivities) I made a new video cable with the said AT lead and the advice above.
    It works a treat!
    3,788
    Not a problem. Glad it worked out for you and you can see what You're doing now
    Do I have to have a switchbox to hook my trs-80 to a TV or can I directly connect my cable to it?
    Quote Originally Posted by tweetykiss View Post
    Ooh. Necroposting.
    Which TRS-80 are you talking about? The Model 1 uses composite video, and you need only build a trivial cable to go from the 5 pin DIN on the back to an RCA plug that you can hook to the composite video input on a modern TV.
    The TRS-80 Color Computer, on the other hand, is a completely different animal. The Color Computer 1 and 2 have only RF modulators, so you need either a switchbox or an adapter to go from the RCA connector to the screw-on F connector on the TV's antenna input.
    The Color Computer 3 has composite color video already - just plug it into a composite monitor.
    -Ian
