Results 1 to 10 of 10
Thread: more powerbook problems
    Mar 2006
    marietta georgia
    517
    Default more powerbook problems
    i finally got a new power adapter today, but soon as i put it on i noticed there was no picture on the screen. no little apple no nothing its like the contrast is turned off just a black screen i had noticed before that i was constantly adjusting the contrast. theres the occasional flash but beyond that nothing any ideas.
    maybe i should appease the apple gods by making an ibm sacrifice.
    So what model of PowerBook is it? Try shining a flashlight at the screen to see if you can see ANYTHING going on. It's possible that the backlight went out, in which case, it's drawing to the screen, but you just can't see it due to lack of backlight. (Contrast and backlight are two different things. On older black and white PowerBooks, you could only adjust contrast. On color PowerBooks, you could adjust both contrast and brightness.)
    You want contrast about in the middle to start with. With the flashlight, look at the upper left of the screen for the arrow (it defaults to the upper left when you turn it on.) Then move the contrast knob/slider back and forth to see if anything changes. (Or press the contrast buttons, if you've got one with buttons instead of a slider or knob.)
    If you can see the arrow, move the trackball (or slide your finger on the trackpad, depending on the model,) and see if the arrow moves.
    If you can see the arrow, and it moves, then you've likely got a bad backlight.
    If you can't see the arrow, no matter what, then you might have a bad screen, screen connection cable, power supply, or a host of other problems.
    Apple ][+ through Retina MacBook Pro, 5150 PC through Core i7 8870/GeForce GTX 1080Ti and quad Itanium 9150M, and many in between.
    Newton, Palm 1000, Palm V, N-Gage, Tapwave Zodiac, iPhone, iPhone X.
    Intellivision, Game Boy through 3DS, Wii, XBone
    Hmm, betting on a open connection myself, maybe around the "pot" for the contrast. I have a Osborne doing that and in my case, one of the leads on a output transistor needs a new solder job. If I tap the case vigorously, I get the flash you talk about. It's really the picture trying to come back but the transistor connection doesn't stay long enough.
    Mar 2006
    marietta georgia
    517
    its a model 140 forgot to metion backlights on amd working
    Mar 2006
    marietta georgia
    517
    also big problem is i cant find a screwdriver to get the boards out i have every torx it seems than the one i need
    Mar 2006
    marietta georgia
    517
    it has decieded to cooperate after a good wack to the back of the screen
    Yep, loose connection. Your wacks work longer than mine do.
    Mar 2006
    marietta georgia
    517
    still working all i need now is a decent word processor thats free
    Jun 2003
    Bellevue, Colorado
    2,437
    Quote Originally Posted by linemanduke View Post
    Have you tried over at lowendmac.com? They have a lot of links for stuff over there. Could find something. I'll keep a lookout for MSOffice for Mac, or something like it.
    Nathan
    The ancients knew *more* than us...
    http://www.legendarytimes.com/forum/index.php They're baaaack!
    Come and see http://www.gamegavel.com for all your gaming needs! We have Zero-ohm resistors!
    Mar 2006
    marietta georgia
    517
    thanks went and looked nothing that i could find but i will keep looking
