Thread: Kaypro 10 Drive Format
    Default Kaypro 10 Drive Format
    I recently acquired a Kaypro 10 that's in really good shape. It boots off the hard drive (which appears to become A: ). There also appears to be a B: (as shown by the "survey" command). I ran a read test of the disk using "check" and it seems to have 4 heads, 17 sectors, 306 cylinders. I can do a directory of drive B: , but I can't copy a file to it. When I try it says, "INVALID FORMAT". Should I try reformatting drive B: ? I can't seem to figure out how to do that...
    Oct 2006
    Boston, MA
    1,292
    Hmm...It seems to me that both drives have a different format. (I am not going to use actual CP/M format names, as I have no clue about them, but will use DOS terms) It is like trying to copy a 360K disk to a 1.44MB disk with the DOS DISKCOPY command. It just doesn't work. But be sure to keep up with the thread, one of our CP/M gurus will be around soon. I think you should reformat the floppy drive.
    Oh, and notice that when you type a colon and then a parenthesis or question mark, you get a face. Just put a space imbetween a colon and another letter AT ALL TIMES. We all figure out what you are trying to say, but it took me awhile. Just click the "edit" button to change that.
    --Ryan
    Last edited by Yzzerdd; November 2nd, 2007 at 09:01 PM. Reason: Wanted to make paragraph look better
    Come to the dark side...we have cookies.
    Wanted: Somebody to buy alot of my stuff
    AT&T PC 6300 site
    Apr 2003
    Saginaw, MI, USA 48601
    8,763
    9
    I'm no guru, but...
    The LL formatting software for the K-10 automatically partitions the 10Mb hard drive into 2x 5Mb partitions. CP/M assigns drive letters at boot time, starting from the boot drive, which is always designated A:, whether booting from hdd or floppy. When booting from hdd, the first partition becomes A:, the second partition is B:, and the floppy is C:. If booted from floppy, the floppy drive is assigned A:, the first partition is B: and the second partition is C:. If your Kaypro is factory stock, this should work, but if it's been modded in some way (hardware and/or software), things may be a little different. From your drive parameters, it sounds like the stock drive, but if it's unable to see the B: partition, you'll need to d/l a copy of the reload set from Dave Dunfield's site (http://www.classiccmp.org/dunfield/img36925/system.htm) and LL format then re-install the software. If there's anything you want to keep, be sure and save it to floppies first. Check all 15 user areas for interesting stuff. The CP/M command is USER 1, USER 2, etc.
    --T
    Apr 2003
    8,763
    9
    Oh yeah, when you d/l the K10G reload set from Dave's site, be sure to read the !READ.ME file, which has instructions for re-doing the drive.
    --T
    Sep 2006
    South Florida
    1,640
    Highly recommended to drop a TurboROM in that puppy, too. Allows using more/different drives, support for more disk formats, more reliable disk-logging, etc... the list of improvements is loooong.
    You can download a copy of the EPROM to burn with a programmer from many places on the net.
    T
