Results 1 to 8 of 8
Thread: Mac Classic Floppy Drive
    Default Mac Classic Floppy Drive
    How sensitive is the drive in the Classic?
    Formatting a disk sometimes don't work for most of my disks, and only a handful actually complete the format.
    Also, even though the system disk is write protected, it managed to wipe it out, and corrupt the file system.
    What do you guys think?
    if you have a working 400K disk drive, consider yourself lucky. vintagemicros.com may be able to sell you a refirb.
    @ BillDeg:
    Web: vintagecomputer.net
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    Quote Originally Posted by billdeg View Post
    Mine is a superdrive, that's what the classic came with..
    Another weird thing is sometimes a write-enabled floppy mounts as write protected.
    Oct 2006
    Boston, MA
    1,292
    I used to own a Classic(and now have a Classic II) and I have NEVER had a problem with the drives. I usually use standard-issue floppy disks(no problems there) but maybe you should go to your local Wal*Mart and spend $5 for some Macintosh formatted floppy-disks. They come in many colors.
    --Ryan
    Come to the dark side...we have cookies.
    Wanted: Somebody to buy alot of my stuff
    AT&T PC 6300 site
    Quote Originally Posted by Yzzerdd View Post
    --Ryan
    This drive even damaged it's own "System Disk" that came with the Classic.
    I think the disk sense switches inside are failing, hence the write protect issue.
    Quote Originally Posted by evildragon View Post
    It could be a switch problem, but I am more inclined to think it might be a Systems error.
    Which MACOS are you running ? OS 7 or something earlier or later than 7 ?
    Croweater
    Mar 2004
    Manitoba North of 50 degrees Latitude
    1,284
    Wow. There are several issues here. If you are talking about a "Mac Classic", TMK they used the superdrive. If your talking about a classic mac up to the Mac Plus which used 400 or 800 byte drives, then that is another thing. But in any case it sounds like youe FD is faulty and should be replaced.
    Lawrence
    Economics isn't a real science. It's an evil art designed for the rich.
    Huh, problem turned out to be a lose RAM expansion card.
