Results 1 to 10 of 11
Thread: Modifying Machine Language Games
    Default Modifying Machine Language Games
    On a particular game, how do I find the code that controls the number of lives a player gets? I would like to change it to 99 lives, so I can keep playing and explore all the levels.
    The games in question are "Shamus" and "Jumpman Junior"
    Thanks
    Hi
    This depends on the environment you are running in.
    If you can run the code under a debugger, break the
    code at the point that it ask for the number of players.
    Usually this will be within a subroutine and the return
    address will be on the stack. Try to disassemble some
    code around the area where one stopped. Look for the
    likely entry point to see if the routine saved any other
    registers.
    This will help in finding the return address on the stack.
    The code will most likely be 2 or three levels back on
    the stack that cares about the numbers entered.
    Work back on the stack and disassemble code until
    you find the location that evaluates the returned
    string.
    The other method is a lot harder. You disassemble
    all the code and try to follow the flow of the code.
    If it is on a PC, it will most likely use standard BIOS
    calls. Look for those that get keyboard input.
    Expect to spend several days figuring out the code.
    If just begining, this can take weeks but a lot will
    be learned.
    Feb 2006
    in the basement
    883
    Dwight wrote:
    ...run the code under a debugger, break the code at the point that it ask for
    the number of players. Usually this will be within a subroutine and the return
    Great technique Dwight!! Please feel free to enlighten us about various methods
    one can use to figure out the purpose of these assembly programs (any)...
    ziloo
    Shamus:
    Unlimited Lives
    Load or reset the game, then execute the following BASIC commands before running or restarting the program.
    POKE 18486,169
    POKE 23558,169
    Jumpman Junior:
    Cheats
    Code	Effect
    Before running the game, type POKE 9450,173	Infinite lives
    http://trs80hack.ytmnd.com/ YTMND: TRS-80 Hacking Secrets Revealed!!!
    There are 10 types of people in this world: Those who understand binary, & those who don't.
    http://mtac.profusehost.net/
    http://mtac.profusehost.net/forum/index.php
    Jul 2003
    Västerås, Sweden
    6,277
    In general, you can use a tool such as Action Replay which will tag certain memory locations and check if they changed the contents once you lost a life. Generally, it is instructions such as DEC, STA and so on that need to be replaced by "safe" LDA, LDX, sometimes NOP NOP NOP.
    What Dwight wrote about stack values unfortunately is mostly bogus when we are discussing Commodore (64) games.
    Anders Carlsson
    Quote Originally Posted by carlsson View Post
    Hi
    Could you educate me in how this is bogus?
    Apr 2003
    Saginaw, MI, USA 48601
    8,763
    9
    All right gentlemen, let's keep it nice and clean, no rabbit punches, hitting below the belt and especially, no ear-biting! Follow my instructions, break clean, and protect yourselves at all times. Now go to your corners, etc, etc...
    --T
    Jul 2003
    Västerås, Sweden
    6,277
    Sorry, I misread your message as there would be a subroutine that decreases a value and leaves it as a return value on the stack for the main program to pick up. The C64 stack is exactly 256 bytes, large enough to hold return addresses and register contents.
    In any case, if you know the expected initial value, it may be a better idea to look for code fragments that hold that value:
    LDA #$04 (LDX, LDY) where the game starts with four lives
    LDA $NNNN (LDA $NNNN,X etc) where $NNNN holds the number of lives
    LDA ($NN),Y etc - not so likely in this case
    However as I wrote, automated tools like AR instead look at locations that decrease counters. Generally, if it finds one, you would work backwards from there to change the cheat to increase the number of lives instead of having unlimited ones.
    Anders Carlsson
    Hi
    I'll admitt that looking for the locatin that has changed
    value will surely find the right variable but little would have
    been learned. I was disapointed that someone just posted
    the values. It meant that he has not learned anything
    other than that he can now play longer without the hastle.
    On the other hand, maybe that was all he was looking
    for.
    I have used similar methods to the one you point to, looking
    for the right code. On my Olivetti M20, I was connecting up
    a hard drive but needed to change the step rate. I just looked
    for code that talked to that port. I took less than a day
    to patch it.
    I've also found that looking at the previous values on the
    stack can be quite informative. On my Poly88, I'd break
    into the monitor code, right in the middle of the queary.
    Looking at the values there, it is relatively easy to find
    the code that cares about the value returned.
    I have a C64 but not played enough with it to know
    what tools are available for it.
    While I agree, learning would be better; I think it's a bit much for this forum expecting to teach someone how to crack a game within several posts.
    Everyone who's posted has the right technique though, you need to run the game under a debugger or on a system that has a built-in monitor (memory editor/disassembler) application. From there you're needing to search memory for the value of interest (converted to hex) so if you had 5 lives you'd search for memory addresses with the value 05. When you die, you'd search for memory addresses with 04 and see which of those used to have 05. Once you find some matches you can goof around and change them to a value you know like 0F for 15 or something (note: choosing a number too high (if the game doesn't support more than 99 lives and you choose FF) it may not work and throw you off).
    The other technique is finding the code that runs each time you die and modifying those commands which they mentioned you could remove the assembly decrement command with NOP commands, etc. This of course will depend what architecture you're on to know what assembly command is valid (DEC on x86, 6502 would be DEC, DEX, etc).. then if you're working in a monitor app you'd probably need to instead know the machine language (compiled) opcode instead of the english word.
    Anyway, quite a lot to try and teach someone in a small amount of time and I too am not sure what is out there for each architecture.
    - John
