Results 1 to 10 of 24
Thread: IBM PC XT 5160 BIOS versions
    5,558
    Default IBM PC XT 5160 BIOS versions
    According to:
    1. Various editions of Upgrading & Repairing PC's (Scott Mueller)
    2. BIOS listing for 01/10/86 version
    3. ROMs in possession
    4. IBM's Technical Reference for the 5160
    5. Internet sources
    6. Contributions from forum members
    08/16/82
    Not much information on this BIOS.
    Mueller's 'Upgrading & Repairing PCs' book doesn't list it, but some other sources do.
    There is a dump of part of BIOS on the Internet. The date string within it is "08/16/82" and the copyright string within it is "5000026 COPR. IBM 1982"
    ROM SIZE = 40K
    ROM U18 = 32K chip labeled with IBM part number of 5000026
    ROM U19 = 8K chip labeled with IBM part number of 5000027 (reused in the next BIOS - dated 11/08/82)
    U18 contains the actual BIOS plus part of BASIC. U19 contains the remainder of BASIC.
    It is possible that this BIOS did not make it into the 5160s released to the public.
    If it did, there can't be too many about because this BIOS was replaced three months later (11/08/82).
    Question: Does the source code for it appear in the first edition of IBM's Technical Reference for the 5160?
    Question: Does anyone actually have a "5000026" stamped chip?
    11/08/82
    ROM U18 = 32K chip
    ROM U19 = 8K chip
    KNOWN ROM SETS = U18=1501512/U19=500027 or U18=1501512/U19=6359116
    ID/SUBMODEL/VERSION = FE/--/--
    * Used on 64/256K motherboards.
    * "The original XT BIOS had all of the features of the latest 10/27/82 PC BIOS."
    Memory map:
    . = unused
    b = ROM BASIC
    R = ROM BIOS
    ------: 0---1---2---3---4---5---6---7---8---9---A---B---C---D---E---F---
    0F0000: ........................bbbbbbbbbbbbbbbbbbbbbbbbbb bbbbbbRRRRRRRR
    ------: ........................|< U19 >|<----------- U18 ------------->|
    01/10/86
    ROM SIZE = 64K
    ROM U18 = 32K chip
    ROM U19 = 32K chip
    KNOWN ROM SETS = U18=62X0851/U19=62X0854 (PROM) or U18=62X0852/U19=62X0853 (EPROM)
    ID/SUBMODEL/VERSION = FB/00/01
    * Used on 256/640K motherboards. Up to 640K RAM.
    * Enhanced POST (one known enhancement is a faster test of RAM).
    * Added support for the 101-key Enhanced keyboard. (Note: Some later released 101-key enhanced keyboards dropped support for the IBM 5160.)
    * Support for 720K floppy drives. Support for 1.2M floppy drives. (Note: 1.2M drives also require a 1.2M compatible floppy controller.)
    Memory map:
    . = unused
    b = ROM BASIC
    R = ROM BIOS
    0F0000: RRRRRRRRRRRRRRRRRRRRRRRRbbbbbbbbbbbbbbbbbbbbbbbbbb bbbbbbRRRRRRRR
    ------: |<----------- U19 ------------->|<----------- U18 ------------->|
    05/09/86
    ROM SIZE = 64K
    ROM U18 = 32K chip
    ROM U19 = 32K chip
    KNOWN ROM SETS = U18=59x7268/U19=62x0819 (EPROM) or U18=62x0890/U19=68x4370 (PROM)
    ID/SUBMODEL/VERSION = FB/00/02
    * Contained some fixes for minor keyboard bugs related mainly to the enhanced keyboard.
    Memory map:
    . = unused
    b = ROM BASIC
    R = ROM BIOS
    Last edited by mbbrutman; December 31st, 2017 at 10:50 AM. Reason: Marked the 62X0852/62X0853 set as 'EPROM'
    According to:
    * The original XT BIOS had all of the features of the latest 10/27/82 PC BIOS.
    The XT BIOS doesn't have the cassette I/O support that the PC BIOS has.
    According to:
    ROM U19 = 4K chip labeled with IBM part number of 5000027
    It's actually 8K I think...
    Although technically correct I always thought each ROM was 4k and since IBM had a HI & LOW rom you ended up with 8k total between the 2.
    5,558
    "The original XT BIOS had all of the features of the latest 10/27/82 PC BIOS" is a quote from the 8th edition (and others) of Mueller's 'Upgrading & Repairing PCs'.
    One mustn't read too much into that. So I wouldn't expect cassette support to be in an 5160 BIOS because the 5160 lacks cassette hardware.
    Likewise, I wouldn't expect to see any code that attempts to read two switch blocks.
    40-32=8 How did I end up with 4 ? I've just replaced the batteries in my calculator, so it doesn't happen again.
    Thanks for picking up my mistake. I've corrected the post.
    5,558
    You're thinking of the AT. Two ROMs each supplying 8 data bits for a 16 bit data bus.
    According to:
    01/10/86
    ROM SIZE = 64K
    ROM U18 = 32K chip labeled with IBM part number of 62X0851
    ROM U19 = 32K chip labeled with IBM part number of 62X0854
    In case you're interested in another data point, I have a motherboard with
    62X0852.U18 and 62X0853.U19. But their contents are the same as the ones
    listed in your post for 10JAN86.
    Bill
    5,558
    Thank you Bill for your contribution. I've amended the first post.
    Quote Originally Posted by wrljet View Post
    listed in your post fr 10JAN86.
    Bill
    Are the checksums of the contents (and not just the bios date) the same as the other ones?
    CRC32 Checksums should be:
    62x0851 = 1054f7bd
    62x0854 = b5fb0e83
    If the checksums are not the same, I'd be interested in seeing what the differences are.
    LN
    Quote Originally Posted by Lord Nightmare View Post
    62x0851 = 1054f7bd
    62x0854 = b5fb0e83
    LN
    The entire contents of the ROMs are identical, byte for byte.
    Bill
    Mar 2006
    Massachusetts, USA
    1,807
    All models of the XT use the same basic board. You can upgrade from a 11/08/82 to a 05/09/86 BIOS merely by replacing the ROMS/EPROMS. This would suggest that the U19 ROM/EPROM is actually a 32K chip with only 8K used. Otherwise, how does the board deal with the two extra address lines when an 8K chip is installed?
