Zenith SupersPORT Case Repair
thenzero
Perry, GA
So I recently bought this zenith supersport from ebay. It works flawlessly but the case was broken pretty badly during shipping. You can see in the pictures that a structural part of the case was completely unattached. I am trying to source a replacement case to rehost the internals but in the meantime I thought I'd try to repair the case at least enough to be usable. After some research I settled on using friction welding with ABS filament. It worked way better than I expected. Thought I'd share the method and the results in case someone else was interested in trying it. Basically you cut a 1.5 inch or so piece of filament and slot it in your dremel. Spin up and apply along the crack. For parts that had a large hidden area not accessible with the welding (like the bottoms of case screw supports) I supplemented with super glue before welding along the outside edges. When I was done I cleaned up they visible areas with a hot knife and then some light sanding to make it prettier. It's not meant to be aesthetic but it doesn't look terrible considering. With some practice I think you could make this look pretty dang good.
See the attached before and after pictures.
316F42FA-6A7B-4EE0-9D62-61FC20F2F58C.jpeg 90C470B9-A612-4429-AE1D-D34655E90CCC.jpeg 0E2C2938-FAFB-4E08-A17C-63BE90AF84B8.jpeg D2B8F420-F807-4D06-A0AB-891292D28143.png D5DC704A-22A0-498A-96B4-380A8049EB30.jpeg 2017AB11-C399-4192-B490-B7581036A6AA.jpeg 000125D3-0803-4808-B31B-0FD322ADEB8C.jpeg
