chjmartin2
- Joined
- Dec 26, 2012
- Messages
- 433
As I have been working on a recent project trying to see how the ATI VGA Wonder (and EGA Wonder at that) are able to display more than 16 colors on a TTL CGA Monitor. I haven't worked it out yet and likely it is some kind of interlaced blending or flickering (but wow it sure doesn't look like it.) Anyway, I went ahead and tried to plug in two monitors at once to the card and I was SHOCKED to discover that the VGA Wonder 16 is outputting SOME KIND of 15 KHz signal on the VGA/RGB port when the CGA Monitor is plugged in. Anyway I don't have an VGA Monitor that is 15 KHz compatible so I can't tell if there is any kind of signal at all or if it is just some sync signal. I said, well maybe I can just buy one - and then I discovered - holy cow they are extremely rare and now very expensive. I went ahead and then thought about it and I realized that CRT monitors are really becoming more rare. I know there are a lot out there but I see all manner of tools to allow retro devices to be hooked up to modern displays - a really cool one being this. (It simulates ARTIFACT COLORS!!!) Anyway I really love CRT Monitors and the retro experience for me is complete when I can use it. The other day playing Silpheed on a CGA Monitor with 16 colors and it just reminded me why I love the CRTs as much as I do. It makes me laugh that modern Pixel artists make things look so perfect when in fact it was so far from that and the grid was part of the image. Anyway, it just got me thinking about what would be the perfect Retro-CRT monitor and I am curious what people think. If you were going to build a modern CRT display for use with old machines what would you want it to be able to do? What would be the ideal size? What feature set would you want? What resolution capability would you need? Here is my view:
Size: I think 15 inches is plenty and would be happy enough with even 13 inch.
Frequency Response: True Multisync - from 15 Khz all the way to 100 KHz
Inputs: Composite, S-Video, Component, 9 PIN TTL (CGA/EGA/VGA), 15 PIN VGA Analog
Features: Can set mode to Amber, Green or B&W Monochrome, Artifact Colors even if using TTL or VGA Analog inputs
What else? What on-screen controls would you need? What adjustments? Should it be 4:3 or something else?
As a side note, I wouldn't know the first thing on how to get started but there is a manufacturer in New York that still makes CRTs, but you would still have to design the display circuit, inputs, design a case and have that made too. Anyway, I am just talking here as I really would like to be able to BUY one. It would probably prove too expensive but so are the old ones that are getting harder to keep running.
Would like others thoughts on this...
Thanks,
Chris
Thanks,
Chris
