fm2606
I was finally able to test my B128-80 yesterday with a new 5-pin DIN C64 video cable. I did a continuity check to verify which RCA jack went to pin 4 of the DIN connector which, to my understanding, is the composite video signal.
When I plugged everything in and turned it on this is what I got ( a white screen with almost uniform black lines in columns).
https://imgur.com/a/rhPoRGp.
After that I tried the jack that went to pin 1 (video out) and got a black screen with tiny white lines randomly appearing on the screen.
Any thoughts on a problem and/or solution?
Thanks
Thanks
