dutchacorn
Some time ago I was lucky to find an Exidy Sorcerer with an S-100 expansion unit, FDC, drives and some software. It had / has some issues which I am working on, which I am documenting on Stardot. There are a few members there that have some Sorcerer knowledge on Stardot but essentially it is an Acorn forum so it does not get much resonance there.
Apart from the last hardware challenge (getting the floppy drives to work) I would like to find a way to back up some of the floppies that came with it.
The Vista VOS CP/M manual states that, to make a backup the floppy used must be initialised. The Vista VOS disk boots to CP/M and I can start INIT. After typing the disk identifier (A) it accesses the disk drive (motor running) and after a while the disk drive head moves a few tracks. Then it asks to confirm initialising after which the floppy drive motor starts running, but that's where it ends; it never stops.
I've tried different drives and different floppies, no change.
It also came with CP/M 2.2, which has a SYSGEN tool, but that does the same.
Thanks!
- Is there something I am doing wrong in this process?
- Is it possible to use a PC to initialize Sorcerer-compatible CM/P disks?
Thanks!
