ebp
When I received my Kaypro 2X, I made a boot disk on a MS-DOS PC with IMD and booted the Kaypro. It booted maybe twice before Drive A quit working. The motor would spin until the door was closed and then it would stall. I swapped drive B for A and got the machine booting again. I found a replacement drive on eBay and the seller bought it for me! Yay! But what to do with the failed drive?
The drive is a Toshiba FDD 5406.
Front:
Model info:
Top view:
Bottom view:
I was inspecting the motor drive board (the one under the platter with the timing marks - see Bottom view) when I noticed that most of the electrolytic capacitors had corrosion on their leads.
I pulled the board, removed the capacitors, and replaced them with new ones and now the motor doesn't stall! Even better, it actually booted the Kaypro! Now I have a spare in case one of the others fails. This might be old news, but if you have a drive with a motor that doesn't spin under load, there might be an easy fix.
Erik
Front:
Model info:
Top view:
Bottom view:
Erik
