I have an OCC1 that powered on and requested a disk. I don't think I have the correct floppy for it (should a Kaypro or Northstar disk work?). Anyway, that is a secondary issue at the moment. The floppy drive seemed to do nothing but spin when I put in a floppy so I opened it up to look inside. It opened easily and I wanted to be sure it was clean and the cables were at least seated properly. Everything looked good, so I powered up again and now the display does not come on. I don't even see a glow in the CRT, however, hitting return spins the floppy again so I'm thinking the display is out. I also tested for proper voltages at the power supply and that looked ok.
I'm wondering how the high voltage AC gets to the display circuitry? All I see is the edge connector on the back of the display assembly that connects to the motherboard. Is this where the high voltage comes in? The gauge of the wire seems very small for that and seems odd that it would be powered from the motherboard? Just wondering if I'm missing something simple. Is there another fuse on the display assembly? Next step would be to rip everything apart to see all parts of the display but trying to avoid that if possible.
Thanks,
Win
Thanks,
Win
