Divarin
I have an Apple ][c and I have been using it with TcpSer running on a nearby PC connected over a serial cable. I've been using various term programs to BBS. The term program I normally use is Apple Term which only supports 300 and 1200 baud. A few weeks ago for no apparent reason it stopped working at 1200 baud but would still work at 300.
By "not working" I mean you type in characters like "AT" and you get a strange characters back.
I have no updated my copy of tcpser or changed the terminal settings on the apple. I also tried some other terminal programs such as Proterm. In proterm I also was able to set higher baud rates so I tried 2400 and 9600 both with the same results.
When using ADTPro I can still transfer data over from PC to Apple at 57600 baud without any issues. I also tried connecting the pc through the same usb to 9-pin adapter to another neaby PC running dos and it can communicate at 1200 or any other baud rate just fine.
I'm kind of at a loss as to what could cause this or what I could investigate next. If it wasn't for the fact that ADTPro is working fine I would say it's the serial cable going into the apple.
I also tried 110 baud just to see what would happen that is working as well so it looks like anything above 300 is not working in any terminal programs I have but is working through ADTPro.
