Yzzerdd
OK, so my Kaypro finally came in. Luckily, it was insured, or so a sticker on it says. It looks nice--except for a few disabilitating dents. There are two, right where the keyboard goes in to the front of the case. They appear fixable, with some careful work with a rubber mallot, a 2x4, and plyiers. It has a few areas that could use cleaning as well. It was sold as working, but I can't seem to get it to work. I power it up, and the power light illuminates, as expected. Both drive lights turn on for a second, but the top(a light stays on. I insert the boot disk, as the manual says. It makes a sound like it reads a single track, then it stops, as does the motor that spins the disk. No text appears on the monitor, it just has a dim green glow to it. I even tried adjusting the brightness, as I have let it run for a while(no boot disk), and it eventually beeps and the motor for the drive clicks off. Any help here?
Also, I the reason I put this thread here and not in the CP/M & MP/M section is because the thread is featured on the hardware, not the software that runs it.
--Ryan
Picture of the Kaypro
Picture of top shipping damage
Picture of bottom shipping damage
Closeup of bottom shipping damage
EDIT: I also notice, when I insert a disk, tap the unit, or open the drive door letting it hit the top with a bang, the screen jiggles. Maybe a bad internal connection? I will investigate tonight
--Ryan
