Help with a CC40 Program
mutantcamel
I've very new to this programming lark. I'm trying to get part of a program running which is in TI99 Basic and change it so it can work on my CC-40.
The originals lines are:
350 INPUT "How much do you want to bet? ":BET
360 IF (BET>SUM)+(BET<0)THEN 350
After numerous changes I came up with for the CC-40 Version
350 LINPUT "How much do you want to bet?";B$:pAUSE 2
360 IF B$=0 THEN 350
361 IF B$>SUM THEN 350
SUM is defined earlier in line 170
170 SUM=100
I'm assuming for the CC-40 to save the value, it has to be a word or letter containing $. Not sure if you would use LINPUT in this situation, INPUT doesn't seem to work.
When running the program I get the error String-number mismatch
Please help I'm stuck!
Hmm...I don't know about this particular version of BASIC but it looks like you're trying to assign a value to a string variable and then doing some boolean logic on it. I think you need an integer variable for this.
Try
350 PRINT "How much do you want to bet?";
355 INPUT B:pAUSE 2
360 IF B=0 THEN 350
361 IF B>SUM THEN 350
170 SUM=100
You may or may not need to define B as an interger before that section of code. For some versions of BASIC it's optional (but often a good idea to).
In MBASIC it's
DEFINT B
(I think. It's been a long time since I've touched BASIC)
