Bondwell b310 backlight fix
Bota
Hello im new in this forum and today i opened a bondwell b310 and inside i tried to disconnect a backlight cable and it got ript from the board. I didint pull any traces but now i only have a ground connection. What should i do? I need a way to find the right line. I also mention that the backlight converter only functions after putting it to 13.4v
So the positive wire is disconnected but the negative is connected where shoud i connect it? I should also mention that i have replaced the connector to a more solid one.
