Announcement
Collapse
Forum Rules and Etiquette
Our mission ...
This forum is part of our mission to promote the preservation of vintage computers through education and outreach. (In real life we also run events and have a museum.) We encourage you to join us, participate, share your knowledge, and enjoy.
This forum has been around in this format for over 15 years. These rules and guidelines help us maintain a healthy and active community, and we moderate the forum to keep things on track. Please familiarize yourself with these rules and guidelines.
Rule 1: Remain civil and respectful
There are several hundred people who actively participate here. People come from all different backgrounds and will have different ways of seeing things. You will not agree with everything you read here. Back-and-forth discussions are fine but do not cross the line into rude or disrespectful behavior.
Conduct yourself as you would at any other place where people come together in person to discuss their hobby. If you wouldn't say something to somebody in person, then you probably should not be writing it here.
This should be obvious but, just in case: profanity, threats, slurs against any group (sexual, racial, gender, etc.) will not be tolerated.
Rule 2: Stay close to the original topic being discussed
  • If you are starting a new thread choose a reasonable sub-forum to start your thread. (If you choose incorrectly don't worry, we can fix that.)
  • If you are responding to a thread, stay on topic - the original poster was trying to achieve something. You can always start a new thread instead of potentially "hijacking" an existing thread.
Rule 3: Contribute something meaningful
To put things in engineering terms, we value a high signal to noise ratio. Coming here should not be a waste of time.
  • This is not a chat room. If you are taking less than 30 seconds to make a post then you are probably doing something wrong. A post should be on topic, clear, and contribute something meaningful to the discussion. If people read your posts and feel that their time as been wasted, they will stop reading your posts. Worse yet, they will stop visiting and we'll lose their experience and contributions.
  • Do not bump threads.
  • Do not "necro-post" unless you are following up to a specific person on a specific thread. And even then, that person may have moved on. Just start a new thread for your related topic.
  • Use the Private Message system for posts that are targeted at a specific person.
Rule 4: "PM Sent!" messages (or, how to use the Private Message system)
This forum has a private message feature that we want people to use for messages that are not of general interest to other members.
In short, if you are going to reply to a thread and that reply is targeted to a specific individual and not of interest to anybody else (either now or in the future) then send a private message instead.
Here are some obvious examples of when you should not reply to a thread and use the PM system instead:
  • "PM Sent!": Do not tell the rest of us that you sent a PM ... the forum software will tell the other person that they have a PM waiting.
  • "How much is shipping to ....": This is a very specific and directed question that is not of interest to anybody else.
Why do we have this policy? Sending a "PM Sent!" type message basically wastes everybody else's time by making them having to scroll past a post in a thread that looks to be updated, when the update is not meaningful. And the person you are sending the PM to will be notified by the forum software that they have a message waiting for them. Look up at the top near the right edge where it says 'Notifications' ... if you have a PM waiting, it will tell you there.
Rule 5: Copyright and other legal issues
We are here to discuss vintage computing, so discussing software, books, and other intellectual property that is on-topic is fine. We don't want people using these forums to discuss or enable copyright violations or other things that are against the law; whether you agree with the law or not is irrelevant. Do not use our resources for something that is legally or morally questionable.
Our discussions here generally fall under "fair use." Telling people how to pirate a software title is an example of something that is not allowable here.
Reporting problematic posts
If you see spam, a wildly off-topic post, or something abusive or illegal please report the thread by clicking on the "Report Post" icon. (It looks like an exclamation point in a triangle and it is available under every post.) This send a notification to all of the moderators, so somebody will see it and deal with it.
If you are unsure you may consider sending a private message to a moderator instead.
New user moderation
New users are directly moderated so that we can weed spammers out early. This means that for your first 10 posts you will have some delay before they are seen. We understand this can be disruptive to the flow of conversation and we try to keep up with our new user moderation duties to avoid undue inconvenience. Please do not make duplicate posts, extra posts to bump your post count, or ask the moderators to expedite this process; 10 moderated posts will go by quickly.
New users also have a smaller personal message inbox limit and are rate limited when sending PMs to other users.
Other suggestions
  • Use Google, books, or other definitive sources. There is a lot of information out there.
  • Don't make people guess at what you are trying to say; we are not mind readers. Be clear and concise.
  • Spelling and grammar are not rated, but they do make a post easier to read.
See more
See less
Toshiba T3200SX
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Toshiba T3200SX
    I have had this lying around for a while, thought I'd try to fix.
    When powered on, after a spell of time I get an error about the clock and "hard disk controller failure" "need setup utility"
    Anyone have experience with the T3200SX? My first question is - does "hard drisk controller failure" actually mean what it says, or is this an error with the hard drive where the controller can't get to the hard drive and fails?
    Does anyone have the parts to repair this.
    It would be nice to get running, it has the gas plasma display w/ 386.
    @ BillDeg:
    Web: vintagecomputer.net
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    #2
    I can't help you specifically. I have a T3100/20 and love the screen which I think is the nicest ever manufactured. Mine has a broken drive which appears to be Toshiba specific so I never got a replacement. I use the machine from one floppy only which is adequate with a 720. Good luck!
    WANTED: Cardinal 2450MNP modem.
    Comment
      #3
      Sounds like your usual CMOS battery problem; I've got a 3200sx (as well as a 3100e); guess I could dig it out. It was working last time I tried it, but for all I know after a couple of years in the basement I'll get the same error .
      Comment
        #4
        Yeah, I like the 3100 as well; I still use it because it's the only portable I had that could have three com ports, which I need for certain serial comm tests (although in the meantime I've acquired a Compaq portable that would be smaller.
        I upgraded the hard disk in mine because 20MB was just too small, but mine is the 3100e and I think it uses standard IDE drives whereas the -20 used a slightly different interface. Any idea what make/model your drive is? Maybe I've still got my original one and maybe I'm out to lunch and they're the same; ya never know...
        Comment
          #5
          I think with my T2200sx I just had to get into the bios and reset everything.
          sigpic
          Comment
            #6
            billdeg:
            I would have thought that the 3200 was a 286 running at 12MHz, similar to the "e" models except with a 40MB drive. Look at this old advertisement (pdf) and that's what it looks like. I find it a bit confusing because they had so many different models and the "e" series also had a 40MB option.
            Edit: OK, I missed the fine print again, lol. It's the SX model which obviously denotes a 386. Also the Toshiba Europe site has some good info.
            Comment
              #7
              I did some research and the "e" series used Conner Periferals 20 or 40 MB HDDs with an IDE interface. The T3100 had a 10MB MFM and T3100/20 had a 20MB 2-7 RLL interface. Too bad, but if anyone has a JVC JD3824ROTO, I'd be interested.
              BTW, here is a good T3100 spec sheet.
              Comment
                #8
                As MikeS says, it's likely a CMOS battery problem. I have one of these, and I get the same error. When I power it on, it goes through POST (a whopping 5 MB of memory!), then gives:
                Time-of-day clock stopped
                Invalid configuration information - please run SETUP program
                Strike the F1 key to continue, F2 to run the setup utility
                When I hit F2, I get CMOS checksum invalid, and "Strike any key"
                I reset the setup screen to defaults and hit F10 to reboot, and it all works just fine.
                I only found this thread by googling T3200SX. I have been thinking of getting rid of mine, thought about posting it on craigslist but haven't gotten around to it.
                Comment
                  #9
                  Yes, I agree that is a problem, but I also get an error message about the hard drive controller, which is really what I am looking for more info about. My original question was about whether the controller is really the problem or whether it's the hard drive. If someone has fixed this specific problem with their system I'd like to hear what they had to do. I don't want to open a laptop without a plan.
                  Bill
                  @ BillDeg:
                  Twitter: @billdeg
                  Youtube: @billdeg
                  Unauthorized Bio
                  Comment
                    #10
                    Yeah,
                    First you need a DOS bootable disk with Test3.exe on it. You can find it on the net. It should seek the disk and boot from it. That is Toshiba's setup utility. That will get you into the setup portion. From there, you should be able to set up the proper parameters for the drive type and floppy. Yeah, either the controller is bad or more likely the Hard Disk is toast. If its an IDE drive, it will be easier to replace.
                    I have a 3200 and I had to find a 26-Pin Citizen floppy drive to replace the bad one (that took a while). The only issue I have now is that the Date will not go past 1999. I would need newer a newer CMOS revision.
                    PS/2s--M-30,M-40SX,M-50Z with AOX Micromaster 386DX, M-57, M-70, M-77, M-80
                    Comment
                      #11
                      Anyone still on this forum with information about Toshiba T3200SX laptops - or, better yet, with parts or a whole unit to sell? If so, please contact me at johnvin999(at)yahoo.com .
                      Thanks,
                      johnvin
                      Comment
                        #12
                        Originally posted by johnvin View Post
                        anyone still on this forum with information about toshiba t3200sx laptops - or, better yet, with parts or a whole unit to sell? If so, please contact me at johnvin999(at)yahoo.com .
                        Thanks,
                        johnvin
                        still looking, as of april, 2013 ...
                        Comment
                          #13
                          What kind of information?
                          What kind of parts?
                          Comment
                            #14
                            Yeah what information do you need?
                            I have a complete working one, but it's my precious, so can't be sold, but I've worked with it quite a bit so know a few things. Also the original brochures/adverts are available through Toshiba Europe - they kept the old models listed and there is one for the T3200SX - easy to get to via google.
                            Twitter / YouTube
                            Comment
                            Working...
                            X
