My trusty Toshiba T1100 is showing it's age.
I only fire up this machine every few months but just the other day it did the following:
Upon booting (with a DOS 3.3 disk in A: drive) - the T1100 starts it's memory test. At 448K it gives 1 long beep and shows ERROR 700D6:0A and sits there. I then press RETURN and it gives 1 short beep and then boots fine from A: drive.
I think I have a RAM problem.
I opened the case (incidentally it's clean as a whistle inside.) I look around inside for some chips to reseat but most every chip is soldered down. I reseat what I can and buttoned it back up.
I get the same boot ERROR every time now. It used to finish nicely at 640K and boot DOS.
So, - I took the T1100 apart again. I pushed and prodded things and nothing helps. I believe when I make the effort to fix this thing, then it should cooperate, but it won't.
Any suggestions, my fellow vintagians?
