TanruNomad
Ok, so I have the omnigo and the proper serial cable to connect to a pc, but when I run the Omnigo Install Manager and attempt to connect to it, it says "was not able to locate an Omnigo on any available port" What gives? I should mention it automatically tries to connect to COM03 and I have no idea which COM my serial port is.
2nd issue: I have Omnicom which is a more advanced and faster connectivity program for omnigo to pc's. When I run it, it says "Omnicom expects an environment variable called OCTTY." Thats followed by a message asking me to enter a port number (1 or 2 are my only options). Once I enter it, it asks for a baud rate (2400, 9600, and 19200 are my only options). I tried combinations of all of these and the result is always the same:
"The system cannot open COM1 port (or COM2 if thats what I chose)
Im running windows 2000XP on a Dell D610
