Can anyone with one of these (or the manual) confirm how you actually put a 16-bit ISA card into one of these things? I know it sounds like it shoud be straightforward, but I can't figure out what you need to remove to access the slot, short of disassembling the whole computer, screen and all. I've removed the plastic panel off the rear, but the screws on the backplate underneath seem to hold the whole case together.
I just find it hard to believe that it would be that involved a process when with its predecessor (kind of) the T3100e it's just a simple matter of unscrewing a panel on the underside to access the expansion slot.
Anyway hopefully someone can point out whatever the obvious thing is I'm missing, so I can add a soundcard into my T3200SX
