NeXT
I'm repalcing the 300mb Type III PCMCIA hard drive in my Badger laptop with a 2gb SanDisk Industrial Grade 2gb card. I'm using the utility I used with my PC110 to make it bootable, then dump the Windows 95 CD onto it for the install. The problem is that the computer is not behaving with the card. I can sys it and that will work boot fine. I can see files and move through directories fine as well. If I add the win95 folder and Setup.exe I can't run the setup because ScanDisk complains that LBA is not enabled on the card and it just starts marking random clusters on the card as bad. I can run Scandisk on another Windows 95 system and it reports absolutely no problems with the card.
If I were to copy my entire Windows CD to the card I can't even run the setup. It just gives a Sector Not Found error.
Now this is where things get weird. If I sys a SanDisk Ultra II 512mb consumer grade card and try the install there is absolutely no problems. I can't spare the 512 unfortunately as I use it in another system plus it would be too small for my liking (and I ahve a pile of these Industrial Grade cards). The laptop has no onboard IDE. The disk has to plug into an internal PCMCIA slot so that's they I went Compact Flash. Am I running into a problem with the computer or with the Industrial Grade cards not behaving 100% to the ATA standard?
