Problem with Toshiba T3200.
Gsector82
For a beer today ive bouth this toshiba pc. Its 25 years old and doesnt work for some reason. It runs memory check and then nothing, only red screen. What shall i do?
4096 kb.
And if there is no MS-DOS (floppy) in it says :
Non-system disk or disk error
Replace and press ane key whaen ready
By the way, i'm sorry for my mistakes. I am russian and sometimes pathetic in english.
No worries. Som of us native english speakers aren't all that great at it, either. :)
As was mentioned, a boot floppy, and a setup program for the BIOS. It should have a hard drive in it, but the CMOS battery has undoubtedly lost power, so it needs to have the parameters re-entered.
The setup prog for the T3200 can be found here:
http://www.pcxt-micro.com/t_download/setup1.exe
Edit:
As MikeS points out below, I grabbed the wrong file, it should be this one:
http://www.pcxt-micro.com/t_download/test3.exe
patscc
MikeS asked
Thanks, I think you're right. The filenames and descriptions line up funny in my browser, they're here, you'll see what I mean.
http://www.pcxt-micro.com/toshiba-dos.html
patscc
I know what you mean ;-) If you import the page into something like Excel it will line up properly.
Lots o' good stuff there; I downloaded it long ago in case it disappears tomorrow.
My 3100 and 3200 both use TEST3; I don't think they used a different setup, but there were both EGA and VGA versions of the 3200 AFAIK.
