So I recently acquired a GRiDCase 3 that is in beautiful shape, except that its modem doesn't seem to work properly. Using the CrossTalk software (on EEPROM), I can't seem to get it to dial, and using the "POrts" command to select COM1 through COM4 just reports "No hardware found" or something along those lines.
I then proceeded to open up the machine, and located the modem next to the battery compartment. The flex cable from the motherboard to the phone jack seems intact, and the double-row 0.1" header that connects the modem to the motherboard seems clean. I made sure that the modem was fully seated, and even pulled it out and reinstalled it a few times to make sure.
So, any ideas? Barring that, does anyone have a spare GRiD modem? Thanks!
