I've recently come into possession of an IBM PalmTop PC110. While the unit came complete with recovery disks, it didn't have any storage besides the internal, 4 MB flash storage found within.
I'm trying to install Windows 95 on this computer. Unfortunately, I need to be able to boot into a partition with more free space than the 4 MB partition, and neither the internal partition nor a 1.44 floppy will do the trick.
To that end, I have a PCMCIA adapter for a Type I CompactFlash card. The card itself is 8 GB in capacity, and I've got another that's 16 GB. A smaller, 2 GB CF card is still on the way.
I have used this solution to help format the drives; http://www.basterfield.com/pc110/ATAinit.htm , which relies on a tool called PCCINIT to handle formatting. And I did use SYS D: or SYS E: from the 4 MB drive, and from a PC-DOS J7.0/V install floppy that came with the PC110. (D: and E: are the drive letters that the PCMCIA storage are assigned by IBM's PCMCIA drivers.) I've also tried to use the standard PC-DOS 7 "format" tool on several occasions, but it doesn't want to format the drive after it's already been formatted by PCCINIT.
Try as I might, though, I am completely unable to get these PCMCIA drives assigned drive letters at startup time by the BIOS. What happens is that when I start up the computer when these formatted drives are connected via the PCMCIA adapters, either I see "Starting up PC DOS..." or "Starting up Windows 95..." and then it freezes, regardless of whether I'm booting from the floppy or the 4 MB internal drive, or I see the stock "Non system disk or disk error replace and strike any key" message if I'm trying to boot from PCMCIA storage.
What is working right now is if I plug in the PCMCIA storage when booted into the 4 MB partition, which has drivers to support swapping PCMCIA cards without rebooting. It is assigned the correct drive letters, and I can read and write to the cards just fine. I just can't boot from them.
Is there another workaround for this that I should know about? Have any PC110 owners had any success in booting from CompactFlash via PCMCIA? What storage devices would be recommended for this computer, if CF via PCMCIA is out of the question?
One last thing. I am aware that this computer has a devoted slot for CompactFlash Type I cards, but every single time I add a card to it, whether while I'm running in the operating system or before I start up the computer, the system locks up. If I add the card before I start up the computer, the system locks up at the BIOS. I have not seen any reports from any of the PC110 websites out there regarding special measures to boot from that slot, and it seems that the majority of PC110 owners from a decade and a half ago were booting almost exclusively from PCMCIA ATA hard drives.
