smp
Hello all,
I've been playing around with my Kaypro 2/84, and now I am wondering how to get source code into it so I can assemble it. In particular, I am interested in getting the Fig-FORTH source code into the machine. This is a significant sized source file, so simply typing it in is not really at the top of my list of options.
My other vintage CP/M machine is an IMSAI with a Northstar floppy disk controller, so I do not have the option of moving a CP/M disk from that machine to the Kaypro.
So, I've been thinking about writing a simple Hex Loader. That's something that I could type in and get running, and then I would be in a position to read Hex files in via the serial I/O port.
The Kaypro has a Z80 SIO in it, as far as I can find out. I've also found out that the data I/O port is port 04H and the control/status port is port 06H. There is a program on my CP/M system disk called BAUDM to set the baud rate for the SIO so I do not have to worry about initializing the device, I only have to read from it and write to it. What I do not know is how to work with the control/status port. Does anyone know what status bit I need to mask for to see that input data is available, and also what status bit I need to mask for to see if the transmitter is ready?
If anyone has any code snippets, I would be grateful to see them. Also, since I have only the CP/M assembler, 8080 code would be most appropriate, but I can translate if necessary.
Thanks in advance for any advice you may have.
smp
smp
