I got a Tandy 600 along with its original AC adapter. Like all new (old) acquisitions, I tested the output of the adapter prior to using it and it had an output over 10V, which is quite a bit higher than the 8V, 1.5A it is supposed to put out. When I opened it up, it was fairly simple (alternator -> bridge rectifier -> cap) and suspecting the rectifier, I checked the pinouts with my multimeter and got this...
So, I am thinking this one is bad and the markings on it are:
GI
KBF-02
8428
From the General Instruments data book, it lists some details:
Max RMS 140V
Peak reverse voltage - 200V
Max current 2.5A
Attempting to find one, I located this possible replacement on Mouser, 627-D4SBL20U-7000, can anyone weigh in on whether or not this is the part that I need? I have ordered caps and IC's before, but have not messed with these.
(-) | (+) | Result |
AC | - | .453 |
- | AC | OF |
AC | + | .470 |
+ | AC | OF |
AC | AC | .002 |
AC | AC | .002 |
GI
KBF-02
8428
Max RMS 140V
Max current 2.5A
