Just picked up an IBM convertible w/ prototype screens
username1
Texas
So, while I was out and about with my older friend fixing my CRT, he mentions that he has an old IBM that he doesn't need and was planning on throwing out. He asks if I want it (which I of course say yes to) and he brings out a rather dirty IBM PC Convertible and two extra screens. HE says he used it daily for quite some time but then stored it in the garage until just then, so it's been sitting for quite some time. He said the two screens he gave me were internal prototypes from IBM during the development that he got from a friend who worked there while it was being made. I cleaned it up from the attached photos, but haven't done anything else to it yet without the proper power supply. He says he probably has one or two somewhere, so I'm waiting on that.
In the meantime, I could use some advice on this. What should I be checking on the internals before powering it up? Is there any way to very that the other two screens are indeed prototypes (they only have one slider, not two, as the attached one has). It's a super nice amchine I want to get running, I'm just not sure of what steps I should be taking. Any advice would be appreciated.
https://i.imgur.com/9FPLho6.jpg
https://i.imgur.com/h1cGK9b.jpg
https://i.imgur.com/S6rvF8U.jpg
https://i.imgur.com/O2FG9j4.jpg
The two extra screens don't look like anything special. IBM had a few revisions of screens; the latest versions were the most readable and they feature two sliders. They might be prototypes; you can't tell without opening them up. But it doesn't look like it from the pictures ...
Get the proper power supply. Have a cleaning diskette on hand. And be gentle ... it's an old machine. I would not open it up except to look at the condition of the main battery, which is no doubt dead after 30 years. It is a NiCAD pack so it can be rebuilt with similar NiCAD cells, but you might not be able to find the exact cells so some physical modifications will have to be made. (It will run fine on wall power without the battery pack.)
I have a portable, I like it quite a bit. That said i'd remove the battery from the unit as a matter of course. It is located in the middle of the rear of the unit. careful with the plastic clip.
I can't speak to the prototype screens. Mine works, so I haven't had any reason to take it apart. yet.
There is no battery in the machine, he said he removed it before storing it, so that's good in that there aren't any leaks (that happened to a PowerBook I have). He said he may have a power supply and will try to find it. I won't power it up without the official one, I'd hate to damage it. Are there any caps inside or chips notorious for going bad?
And finally, can I just tape over the high density hole on my 1.44 meg floppies? I don't have any 720k disks, although he again said he may be able to find some for me. I cleaned the shell up pretty nicely, next I'm hoping to clean the keyboard properly and take a look at the disk drives and other stuff. Where would be the best place to sort out boot disks? I can write them, just need an image.
Read this ... http://www.brutman.com/PCjr/diskette_handling.html
The short story - do not use 1.44MB floppies (high density) with tape over the hole that indicates the diskette type. The machine needs double density, 1MB floppies, not the more common 2MB (unformatted, 1.44MB formatted) high density floppies.
Mike
Thanks, I will keep that in mind about the floppy disks. As far as the possible prototypes, I've carefully opened them and photographed the insides and dates in hopes of finding a solid answer on what they are. First is the black on green with streaks on it. Date is 12-9-86
https://i.imgur.com/7IHLUGD.jpg
https://i.imgur.com/tv8UZW9.jpg
And secondly, the other monitor. This one is very strange and has an effect that is hard to capture in photos. It almost looks like there isn't a screen at all, you can see the circuit boards clearly behind the glass. I did my best to photograph this on my phone. It is dated both April 22 and 24 of 1986.
https://i.imgur.com/vAjaxBv.jpg
https://i.imgur.com/6tuBim0.jpg
And the screen effect. You can sort of see the PCB, it is much clearer in person without the reflections. Still, if you zoom in you can see the gold and green of it.
https://i.imgur.com/79tASVt.jpg
So yeah, if anyone has this info on what these could be, I'd love anything you can tell me.
In other news, I cleaned up the case a lot and checked the internals. It has 4 ram cards and all in all looks incredibly clean inside. I think once I have the power adapter it'd be safe to turn on, although I still have yet to find disks and I would want to first clean the drives.
Probably not prototypes since the displays were made after the 5140 was placed on sale. More likely, the owner of the 5140 took advantage of IBM's offer of a cheap replacement display as IBM introduced more readable LCDs.
Determining exactly what you have would require close up pictures of each of the three display models IBM produced for comparison.
Mike
Lesson learned! I killed a perfectly working 5140 convertible drive by letting it read 1.44MB diskettes faked with 720K capacities. It read things like MS-DOS fine at first, but then it started to go completely off the wazoo after a game of Insanity; I think it failed to read past track 0 as of now....
I don't think that using the wrong media in a floppy drive will "kill" the drive. It's more likely that the media that you used was just simply flaking due to old age, and it left residue on the heads.
Clean it with a cleaning diskette and isopropyl alcohol. This happens to floppy drives all of the time.
Well, after all, I did hear no popping capacitors, so that's a good sign. This IBM 5140 was however new; it came completely unused from a warehouse, so the disk drives still had their plastic anti-dust diskettes, although the LCD is damaged; And the diskette I used that caused the drive to repeatedly whirr was read perfectly in many USB drives before. Then again, they have different mechanics from real, older drives... I'll try seeing how the cleaning will go.
P.S.: I'm still willing to offer the LCD for parts if anyone wants to take a stab. Also will be more glad if I can be offered a fully working screen. It only has a very, teeny tiny bit of plastic chipped off from my attempts to disassemble it; quite a nice board inside there too! Capacitors look clean and fresh, which also confused me trying to trace out the problem.
Managed to scrounge some actual IBM 720k disks for free, still trying to source a power supply. If anyone has an extra, please PM me.
Good news in that today I think I made a boot disk for the PC Convertible, with all of the PC Convertible programs on it. Very convoluted process to write it, but it's on a good 720k disk and tested in virtualbox. Of course, it will not actually let me run anything, as it detects if it is actually on a 5140, but the fact that it booted gives me hope that it worked correctly.
https://i.imgur.com/IO05eeY.png
Am still in need of a 5140 power adapter, if anyone has one or a link to a compatible one, that would be fantastic. It needs to be 15V, 2.7 amps, 5.5mm x 2.5 mm, center positive. If you have anything, PM me please.
I now have a compatible power adapter and finally got to fire it up! It beeped on power on, both drives spun up, went into basic. Gives me a clock error on bootup but that's because it keeps forgetting the time when I unplug it as there is no CMOS. It turns out only one of my three screens works and it is easily the least useful of the lot. My backlit screen whines and shows random lines, my reflective one is leaky inside and only a few lines work. The one screen that does displays properly has some weird anomalies. There seems to be no reflective material behind the screen, you can see right through and look at the circuit boards. As such, I need a very direct, bright light to see it at all. As such, I'm now looking for a backlit screen to purchase. Here are some photos of what I have so far.
backlit broken:
https://i.imgur.com/STaU28t.jpg
reflective broken:
https://i.imgur.com/qpwcGVt.jpg
non-reflective working:
https://i.imgur.com/ZVasGN3.jpg
https://i.imgur.com/sfLkmW5.jpg
the circuits visible on the non-reflective:
https://i.imgur.com/76gZSW0.jpg
Anyone know anything about why this screen would be like this? I know the last owner said there was one or two prototype screens, does this provide any evidence one way or the other? There is a serial number on the inside of the screen (backwards) that reads (to the best of my ability): "EPSON LD-BU8953J-5", then a line break, then "JAPAN ..... 622N"
