bttr
Hi!
I'm the proud owner of two 800CTs: One with a P100 and 16MB RAM, the other with P166MMX and 48MB RAM.
Recently I fiddled around with the OmniBook Support Utility Disk and found three tiny tools there: DOCK.COM, EXTFLOP.COM, and IDE.COM
DOCK.COM source code:
EXTFLOP.COM source code:
IDE.COM source code:
Source code is for the R86 assembler, which is part of http://www.lsi-j.co.jp/freesoft/. Don't ask, I just like R86.
But this source code is easy to convert to NASM or even DEBUG.
Now my problem is, these tools don't work for me.
Whatever I try, ports 66h and 67h always return FFh. I also verified with DEBUG.
Okay, EXTFLOP.COM is never called from the Utility Disk, but DOCK.COM is.
(I didn't try IDE.COM, as it also reads the same status byte EXTFLOP.COM.)
What I already tried:
Am I doing something wrong?
Would be nice, if some other people could try on their own machines.
OmniBooks 300, 425, 430, 530, 600, are probably worth to try own too.
CSEG
RS 100h
; --- Read status.
in al, 66h
; === Use bit 4 only as return code.
; --- Make bit 4 the lowest bit.
ror al, 1
ror al, 1
ror al, 1
ror al, 1
; --- Kill all the upper bits.
and al, 1
; --- Call DOS function "TERMINATE WITH RETURN CODE".
mov ah, 4Ch
int 21h
END
CSEG
RS 100h
; --- Read status.
in al, 67h
; === Use bit 3 only as return code.
; --- Make bit 3 the lowest bit.
ror al, 1
ror al, 1
ror al, 1
and al, 1
mov ah, 4Ch
int 21h
END
CSEG
RS 100h
; --- Read status.
in al, 67h
; === Use bit 2 only as return code.
; --- Make bit 2 the lowest bit.
ror al, 1
ror al, 1
and al, 1
mov ah, 4Ch
int 21h
END
Setup | 66h | 67h
800/166 BIOS 2.01.00 gr | --- | ---
Boot from HDD | --- | ---
FDD not connected | FFh | FFh
FDD connected (hot-plug) | FFh | FFh
Boot from FDD | FFh | FFh
Boot from HDD (docked) | --- | ---
Boot from FDD (docked) | FFh | FFh
800/100 BIOS 2.00.00 en | --- | ---
