AndyO
I have a Compaq Portable III which has suffered what appears to be a significant impact on the bottom corner where the power lead connects, and on the side-panel where the vents are for the power supply.
The bottom corner of the casing, and the PSU itself is deformed, but the main part of the damage is that the metal panel up the side of the PSU - the metal has holes for ventilation - has been pushed in as much as 3/4 inch along the 'top' (meaning along the edge of the PSU that runs close to the back panel.
I was able to disassemble the computer to the point where I can get at the whole PSU, where it looks like it's designed to simply slide out as a complete assembly.... but it doesn't budge, and there's no place where it appears I can exert any leverage or force.
It's possible that the PSU is jammed in place by the deformity, or that I have missed some screws that hold it in place, but I don't think that's the case.
Does anyone know if the PSU really does 'just' slide out, once the back panel and motherboard are removed? If I can source one, and can remove the damaged unit, I'd certainly want to get this back in working order, even if with superficial damage to the outer case.
Incidentally, the system doesn't power up - which is probably no surprise.
Any thoughts?
Any thoughts?
