Hi,
Picked up an Epson PF-10 disk on a Ebay auction last year and have started working on getting it connected to my Epson PX-8.
When I plug it in with the nicad battery pack, the Battery light turns on - I'm sure the battery pack is bad.
I then insert new 4 C batteries, turn it on and the battery light does not turn on, but either does the "Power" light on front.
When i insert a floppy disk, the disk does not spin and the unit makes no noise like it is operating....
I opened it up and noticed that there is an internal 4.7v internal battery. If this battery goes bad will the unit still work? Documentation says that it is for backup....
Here is a picture of the disk drive opened up - the long yellow thing is the internal battery:
Also - the disk drive did not come with a cable - so I created a #723 cable myself with this pin configuration:
Pin 1 to Pin 5
Pin 2 to Pin 3
Pin 3 to Pin 1
Pin 6 to Pin 2
Pin 7 to Pin 4
Does this seem correct for the PX-8 ? Got the pin configuration from a PX-8 users manual....
Let me know if you have any ideas or suggestions...
Derek
Pin 1 to Pin 5
Pin 2 to Pin 3
Pin 3 to Pin 1
Pin 6 to Pin 2
Pin 7 to Pin 4
Derek
