tezza
Yesterday I disassembled my unit to get at the floppy drive. I think it's faulty as it doesn't spin on boot-up. It could be a CMOS problem, but I wanted to check cables and replace the drive first then try to boot, just to eliminate the broken drive theory.
Boy were these ever needed! I had to use at least three different sizes.
With no manuals or guides, getting into the machine was a bit of an adventure. I took it slowly, and step by step figured out how to do it. The hardest bit was getting the plastic plates off the rear end so I could pull the main assembly out of the case. I now understand another person's reference to needing a flat-blade screwdriver. You need this to prise the plastic cover off...carefully, without breaking the plastic snap-clips holding it on. It wasn't easy. Maybe there is a technique to it I don't know about?
Anyway, it survived my ham-fisted efforts and eventually I managed to remove the case, then the drive.
I then discovered that the drive wasn't your standard PC 3.5 inch drive. The connector at the back was a 26 pin one as opposed to the standard 34 pin one! (see pic...slt-286 drive on the bottom).
Oh well, so much for replacing the drive. As I said, I'm not convinced it's the drive (If I'm honest with myself, I really just wanted to see what was inside the machine). It might be the controller itself or a CMOS problem caused by a flat internal battery as discussed in another thread. The error at the beginning mentions the floppy controller. When I boot it up again I'll post the exact error. Hopefully, someone can throw some light on the problem.
if you can, get a set of "tamper-proof" torx bits, they are more universal.
If you ever need to fix a compaq, you'll DEFINITELY need them then ;-)
