Announcement
Collapse
Forum etiquette
Our mission ...
This forum is part of our mission to promote the preservation of vintage computers through education and outreach. (In real life we also run events and have a museum.) We encourage you to join us, participate, share your knowledge, and enjoy.
This forum has been around in this format for over 15 years. These rules and guidelines help us maintain a healthy and active community, and we moderate the forum to keep things on track. Please familiarize yourself with these rules and guidelines.
Remain civil and respectful
There are several hundred people who actively participate here. People come from all different backgrounds and will have different ways of seeing things. You will not agree with everything you read here. Back-and-forth discussions are fine but do not cross the line into rude or disrespectful behavior.
Conduct yourself as you would at any other place where people come together in person to discuss their hobby. If you wouldn't say something to somebody in person, then you probably should not be writing it here.
This should be obvious but, just in case: profanity, threats, slurs against any group (sexual, racial, gender, etc.) will not be tolerated.
Stay close to the original topic being discussed
  • If you are starting a new thread choose a reasonable sub-forum to start your thread. (If you choose incorrectly don't worry, we can fix that.)
  • If you are responding to a thread, stay on topic - the original poster was trying to achieve something. You can always start a new thread instead of potentially "hijacking" an existing thread.
Contribute something meaningful
To put things in engineering terms, we value a high signal to noise ratio. Coming here should not be a waste of time.
  • This is not a chat room. If you are taking less than 30 seconds to make a post then you are probably doing something wrong. A post should be on topic, clear, and contribute something meaningful to the discussion. If people read your posts and feel that their time as been wasted, they will stop reading your posts. Worse yet, they will stop visiting and we'll lose their experience and contributions.
  • Do not bump threads.
  • Do not "necro-post" unless you are following up to a specific person on a specific thread. And even then, that person may have moved on. Just start a new thread for your related topic.
  • Use the Private Message system for posts that are targeted at a specific person.
"PM Sent!" messages (or, how to use the Private Message system)
This forum has a private message feature that we want people to use for messages that are not of general interest to other members.
In short, if you are going to reply to a thread and that reply is targeted to a specific individual and not of interest to anybody else (either now or in the future) then send a private message instead.
Here are some obvious examples of when you should not reply to a thread and use the PM system instead:
  • "PM Sent!": Do not tell the rest of us that you sent a PM ... the forum software will tell the other person that they have a PM waiting.
  • "How much is shipping to ....": This is a very specific and directed question that is not of interest to anybody else.
Why do we have this policy? Sending a "PM Sent!" type message basically wastes everybody else's time by making them having to scroll past a post in a thread that looks to be updated, when the update is not meaningful. And the person you are sending the PM to will be notified by the forum software that they have a message waiting for them. Look up at the top near the right edge where it says 'Notifications' ... if you have a PM waiting, it will tell you there.
Copyright and other legal issues
We are here to discuss vintage computing, so discussing software, books, and other intellectual property that is on-topic is fine. We don't want people using these forums to discuss or enable copyright violations or other things that are against the law; whether you agree with the law or not is irrelevant. Do not use our resources for something that is legally or morally questionable.
Our discussions here generally fall under "fair use." Telling people how to pirate a software title is an example of something that is not allowable here.
Reporting problematic posts
If you see spam, a wildly off-topic post, or something abusive or illegal please report the thread by clicking on the "Report Post" icon. (It looks like an exclamation point in a triangle and it is available under every post.) This send a notification to all of the moderators, so somebody will see it and deal with it.
If you are unsure you may consider sending a private message to a moderator instead.
New user moderation
New users are directly moderated so that we can weed spammers out early. This means that for your first 10 posts you will have some delay before they are seen. We understand this can be disruptive to the flow of conversation and we try to keep up with our new user moderation duties to avoid undue inconvenience. Please do not make duplicate posts, extra posts to bump your post count, or ask the moderators to expedite this process; 10 moderated posts will go by quickly.
New users also have a smaller personal message inbox limit and are rate limited when sending PMs to other users.
Other suggestions
  • Use Google, books, or other definitive sources. There is a lot of information out there.
  • Don't make people guess at what you are trying to say; we are not mind readers. Be clear and concise.
  • Spelling and grammar are not rated, but they do make a post easier to read.
See more
See less
Replacing Battery Cells on Powerbook 180
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    I recently obtained a Powerbook 180 that needs some work. It boots but has a damaged LCD (may have a replacement from a 145 that does not boot). Although the battery is bloated and corroded. I was able to open it up quite easily without breaking any plastic and to no surprise all 10 cells are done for.
    My question is if anyone has any experience replacing these cells and what batteries are suitable as replacements? An older post here from 2013 says someone used Varta Ni-Mh AA cells but they seem too small in size to fit the battery case.
    Click here for my YouTube Channel on old commercials and abandoned places!
    #2
    Without a picture of the original batteries, I can't be of much help, but if the original batteries were NiCD, you can use NiMH batteries to replace them.
    There is a NiMH/NiCD battery size that looks close to AA, but they're a bit fatter and shorter, this might be what you have, but without pictures, I can only speculate.
    Comment
      #3
      I took a picture with a tape measure for size. The only markings on the cells are the polarities and JAPAN so I can't tell what material they're made of. They seem to be two inches wide.
      Comment
        #4
        Yeah, that is the weird size I was thinking of. I think I have a few of those in my garage, I'll see if there's any markings on them saying what they are.
        Comment
          #5
          Closest I could find is a 4/5A cell:
          https://www.onlybatteries.com/showit....31&cat1=&uid=
          You'll need to compare the battery sizes. A 4/5A is 17mm diameter and 42mm long. The critical dimension is the diameter, it doesn't matter if the batteries are a bit shorter, it'll give you more working room. Regardless of the size, the new NiMH batteries will have a significantly higher capacity than 30 year old NiCD battery technology. I'd be surprised if the old batteries were even 1200 mAh new.
          Comment
            #6
            I'm in the same project for the same laptop ( powerbook 180 )
            Maybe later for a powerbook 100 (hwihc i'm waiting today )
            Strangely enough, in my case, the batteries look like AA to me, and not exactly set up in the same way as this picture, the battery even looks different.
            I planned to replace with new NICD (in Europe you can still find them in the western countires like poland or ukraine) but these are mostly new old stock now, and even if they are new they don't last long.
            So I'll swap the nicd with nimh for the first time.
            Beware that if the batteries themselves are clearly a good fit to power on the laptop (1,2V in both cases), the way they are charged differs. Back in the day they were charged with constant voltage and nimh needs constant current. If you swapp them it's likely they'll get "some" charge - but I would trust this process much. Ideally you should hack an external charger for your homemade battery pack.
            As a comparison I replaced the batteries on a toshiba 2130 (486DX vga laptop) with new 4/5 AA NICD from Poland (twice the capacity of the original!) and the laptop works probably even better than back in the day, holds charge for half a day , and charges perfectly with the laptop power cord.
            (Helas they don't have stock anymore.)
            Comment
              #7
              The more I look at your picture the more I think this is not the stock PB180 battery - but a rebuild of some sort.
              I'll share pictures of mine, it has no wires in it (only wide copper channels) and it has two weird looking thermistors (?) stuck between batteries
              The case itself was also extremely difficult to open ( ultrasound soldered )
              Comment
                #8
                No, you can't! NiMH cells require controlled charging, while NiCD cells don't. Just using NiMH as a replacement of NiCD is very, very dangerous and should not be recommended to anyone.
                The PB 180 should already use NiMH, however.
                Comment
                  #9
                  You're confusing NiMH with Lithium Ion.
                  NiMH charge characteristics are virtually identical to NiCD and they can be interchanged in almost all cases.
                  The Powerbook 180 uses either NiCD or SLA batteries, depending on the pack type.
                  Comment
                    #10
                    I thought about this too. The case was simple to open and the black padding on the upper right and left looks like hardware store electrical tape. I have another Powerbook 145B in storage that has a dead battery as well but I haven't taken it apart. The only reason I cared enough about this one is because it began corroding outside of the shell and onto the Powerbook itself. I'd like to repair the battery into working order but worse case scenario I'll empty the battery case and keep the circuitry in the event I sell it and the future owner wants to rebuild it.
                    Here is another image for diameter. The left cell is a AA I had on hand for comparison. The length of the AA and Powerbook cells are the same but the diameter of the Powerbook is slightly larger.
                    Comment
                      #11
                      Because the PB cells are 4/5A, not AA. You can use AA batteries, but you won't get the same capacity. AA NiMH batteries top out at around 2000 mAh, while 4/5A can go up to around 2800 mAh.
                      Comment
                        #12
                        Yeah, I repacked a NiCd battery pack for a Motorola “brick” cell phone with NiMh and it has been working fine for a few years now, and has insane life. Probably far more than it did even when new. About to do the same with a Compaq SLT battery pack. Finding good NiCd cells in 2021 is really more trouble than it’s worth.
                        Compaq - It simply works better
                        Comment
                          #13
                          They are available, just not in high capacities. You can get them in 150-300 mAh capacities pretty easily and 600 mAh if you look a bit harder, but above that is where it gets hard. The only reason they still exist is because Chinese companies that make those 99 cent solar garden lights use them over other battery types because they're so cheap. Once the ROHS ban went into effect, the bottom fell out of the cadmium market I guess.
                          It's ironic they ban cadmium because it's a heavy metal that causes health issues, but so does nickel, and it wasn't banned or restricted lol.
                          Comment
                            #14
                            Yeah, I need much higher capacities than that generally, like my Compaq SLT battery for example was a 2400mah unit, 10 cell 12v, so I would need at least 2400mah cells for it (because I don’t like the idea of reducing the capacity by using smaller cells). That’s why I’m going with 3000mah NiMh cells instead.
                            From what I’ve read, I believe NiCds are MORE toxic than NiMh, though I’m certainly no expert in heavy metals. Obviously, ALL batteries are toxic to the environment to some degree if they aren’t properly disposed of, but I was always under the impression that NiCds were particularly nasty.
                            Comment
                              #15
                              Cadmium is one of the more toxic heavy metals, but nickel isn't far behind. Ions and compounds of nickel are known carcinogens, and can cause plenty of nasty health issues. Nickel allergy is a thing that many people have just touching the metal.
                              NiMH batteries are less toxic than NiCD batteries, but not that much less toxic.
                              Comment
                              Working...
                              X
