MauriceH
Having some problem building a new system
I am Running UBUNTU. (I am a complete newby at Ubuntu)
Followed these steps simh-pdp8. (link)
attach the mentioned 3 files.
Boot RX0 -all went well.
Then I am stuck at :
"We start with formatting the disk with the ZERO command:"
.ZERO RKA0:
OUTPUT ERROR
.ZERO RKB0:
OUTPUT ERROR
I get these errors.
Next followed the steps to build.
I run:
".RUN SYS BUILD"
Did a Print and insert the PT8ETR,indeed the * is now at PTR
also I notice the SYS * is at RX8E
Ok , Then want to use the RK05.
$DSK RK8E:SYS
To mark the RK05 drive as the system device:
$SYSTEM RK8E
$BOOT
?SYS
-So a failure, what goes wrong here?
Then I took: BUILD the new device
All went well till : And with Print System is at RK8E*
"Run BOOT again and it should work. " Well How to BOOT at $ -prompt.
Save the BUILD data:
.SAVE SYS BUILD
QUESTION:
If I type at "$"prompt BOOT, system hangs.
Then How do I get to the "." DOT-Prompt. to save the build.
Have no clue how to get to the DOT-Prompt from $.
Cntr-E gets me back to sim> and have to start over again.
Cntr-C gets me to DOT but if I :
.SAVE SYS BUILD
I get a SAVE ERROR
If I at "DOT"-prompt type .BOOT RK0 I get a "/" prompt
Thanks for the help
.ZERO RKA0:
OUTPUT ERROR
.ZERO RKB0:
OUTPUT ERROR
I get these errors.
I run:
".RUN SYS BUILD"
$DSK RK8E:SYS
SYSTEM and BOOTSTRAP
The SYSTEM command specifies devices that are system handlers. .......
$SYSTEM RK8E
$BOOT
?SYS
.SAVE SYS BUILD
QUESTION:
.SAVE SYS BUILD
I get a SAVE ERROR
Thanks for the help
