fatwizard
Hi,
I am usually found lurking around the vintage PC parts of the forum, but I do own one Mac, a Performa 6300CD Power PC model. I have taken a notion to see if I can get it running again. It is nearly dead. When you attempt to power it up you get a small quick sound (not a beep)from the internal speaker, and nothing else.
The power supply has a 14 pin connector, and I was wondering if there was a way to test this supply akin to the jumper test for an ATX style PC supply. I have tried pulling all devices out of the machine save the mainboard with ram and the power supply with no change in symptom. I know the hard drive is bad in this unit, and I fear it may have caught some lightning.
I have almost never worked on a Mac, and I'm pretty lost. Any insight would be very much appreciated.
