tinkerBOY Experienced Member Joined Dec 6, 2016 Messages 96 Location Philippines Apr 17, 2021 #1 I'd like to know if I can use, for testing purpose, a floppy controller card from an IBM 5150 to an 486 motherboard with 16-bit ISA slots?
maxtherabbit Veteran Member Joined Apr 23, 2019 Messages 2,153 Location VA, USA Apr 17, 2021 #2 You absolutely can. Just bear in mind the same limitations of the card will still exist. Only works at 250kbps MFM
tinkerBOY Experienced Member Joined Dec 6, 2016 Messages 96 Location Philippines Apr 18, 2021 #3 maxtherabbit said: You absolutely can. Just bear in mind the same limitations of the card will still exist. Only works at 250kbps MFM Click to expand... I can't seem to get it working though. I tried setting 360k or 1.2M in the bios but it won't boot. By the way Im using a Gotek drive which also works fine with a IBM 5150 motherboard using a 360k image file.
Chuck(G) 25k Member Joined Jan 11, 2007 Messages 44,437 Location Pacific Northwest, USA Apr 18, 2021 #4 If your 486 motherboard already has a floppy controller on it, do note that you'll have to disable it before adding the 5150 board.
tinkerBOY Experienced Member Joined Dec 6, 2016 Messages 96 Location Philippines Apr 18, 2021 #5 There’s no buitin floppy/ide controller nor external card inserted.
