F fjk61011 Veteran Member Joined Nov 18, 2009 Messages 1,724 Location Dublin, Ireland Jun 11, 2021 #1 Is it possible to disable the onboard video on a PS/1? I want to use a vga adapter card.
T This.is.Matt Member Joined Jun 13, 2013 Messages 41 Location Southsea, United Kingdom Jun 12, 2021 #2 Should be - if your board takes 30-pin SIMMS, you'll need to switch JP10. If it takes 72-pin modules, then swap J15.
T-R-A Veteran Member Joined May 17, 2009 Messages 661 Location Western NC Jun 13, 2021 #3 No. You can't, at least according to: http://ps-2.kev009.com/pcpartnerinfo/ctstips/52d2.htm "Video: Note: The Display powers the System Unit; the two cannot be operated separately. There are NO "Video Disable" Jumpers."
