ButINeededThatName
So I recently pulled this system out to work on it again after letting it sit to focus on some other projects (needed a new hard drive, drive cable and floppy drive) and I am no longer able to access it's BIOS/setup program. Upon powering it on it will do its memory test then come up with "Invalid Configuration". Apparently this is due to the system battery dying and what I need to do is run the setup utility (ref367).
Well, I made the appropriate diskette and it won't seem to boot from floppy. I've written a couple of different disks and tried four different drives (an Alps, two Mitsubishi's and a known working Sony 2.88 drive) with no luck so far. Am I missing something here? The information on these isn't great, but I'd assume you treat it like a normal PS/2 that's lost it's configuration and just boot from the appropriate refdisk and restore everything.
