Hi, new here.
I have a 80486sx-25 system, with Evergreen AMD 5x86 (100-133MHz) Overdrive and 32MB system memory (48MB max onboard). This was bought almost 20 years ago. I put the Overdrive CPU a few years later. It came without external motherboard cache (IC slots empty). And since then I've been trying to get it to work.
Per the technical reference booklet, it requires the following:
- one non-parity instruction chip 8kx8 at 15ns, mandatory
- one parity instruction chip 8kx9 at 15ns, mandatory
- four non-parity 32kx8 or parity 32kx9 data chips, at 25ns
The problem is that once I've put the cache chips in, it freezes right after it senses them. Per the booklet this is supposed to make a cache of 128k, but onscreen it shows as 256k cache, although, as said it freezes right after that.
The chips that I have (28-pin plastic skinny DIPs):
- four 32kx8 25ns
- four 32kx8 20ns
- two 8kx8 15ns
- one 8kx9 35ns
I tried either the 20ns or 25ns data chips. Notice the 8kx9 instruction chip is 35ns, not 15ns, as instructed by the booklet. A 15ns 8kx9 is a bitch to find on the internet. Only those wholesale houses/dealers have them to be bought by auction and minimum costs/quantities. Could the 35ns be the freezing problem (timing issue?), or could there be a motherboard problem?
I want to know why the screen is showing 256kb cache when the booklet says this should be 128kb, unless the booklet is wrong or something. Currently running Windows 98SE and I think it would be a little nice if it had some sort of L2 cache to increase performance a few percent. Anyway, you may request further details. I can also furnish photos or scans, etc. Thanks in advance.
~tech
- four 32kx8 25ns
- four 32kx8 20ns
- two 8kx8 15ns
- one 8kx9 35ns
~tech
